RARE NEW Techtom CMX100 monitor Water Temp/MPH/Inj Cycle/Air Flow Meter)$165.00
The TECHTOM CMX 100 is extremely rare and discontinued. It can no longer be aquired and this is one of only 2 known Brand New Units availible complete with english instructions!
This unit is small and very compact. No install required as it plugs right in tho the factory OEM diagnosic port - Displays 4 parameters - Peak hold feature - Connects to consult port - Ultra compact size Available for most Nissans from 90 on with the consult connector. This amazing unit packs many features into its tiny box (about half the size of credit card!). Select one of the parameters from the list and view real-time data while you race or tune. Each parameter come with a peak-holding option just like conventional gauges. Simple to operate - just two push switches. Displays in bright red LED distinctive and easy to read at a quick glance Reads in Standard US units Speed (mph) Mile Per Hour Water Temp. (°F) Farenheit Air Flow Meter (V) Voltage Injector Duty Cycle (%) Percentage Compatible with all OBD I Applicable U.S Models: 90-96 Nissan 300zx NA and TT 91-97 Nissan 240sx S13 and S14 96-97 Nissan Pathfinder 96-97 Nissan Truck 91-97 Nissan Sentra / NX 1600 and 2000 92-97 Nissan Maxima (24 Valve Engine) 93-97 Nissan Altima 90+ Nissan Stanza 90+ Nissan Axxess 90-97 Infinity MORE PICS: http://i214.photobucket.com/albums/c...chtomplug1.jpg http://i214.photobucket.com/albums/c...chtomplug2.jpg Last edited by CPARKPowertrix; 12-24-2008 at 08:55 AM.. |
![]() Join Date: Oct 2004
That thing is rare, i tried finding one for the longest time before I sucked it up and bought a blitz r-vit.
Its def. worth the price, glws
Still availible
Still availible. Would make a great Christmas Present
Works with all SR20 swaps
Works with SR20 Swaps as it will plug directly into the OEM OBDI diagnostic port located on the inside drivers kick panel area.
Yep sure will
Yes, It will work on swapped cars too. Nissan reads the parameters the same way on an SR20. It is taking readings from the same type of sensors attached to the ECU:
water temp sensor Air flow meter injector cycle MPH All in which read the same from the ECU. That is why there are so many other Nissan (OBDI) cars that this will work with as well. |
![]() Join Date: Dec 2002
Three wires have to be hooked up, most swap guys don't know how but it's easy. Green, green/white, and green/black, TX, RX, and CLK are the ECU pinouts.
Someone buy this, it's a GREAT diagnostic as well as monitoring tool, and the price is a steal.
Still availible
Still availible.
Would this work on a 1990 Coupe with with a 1995 swap? From what I have read in the archive about swapping from Sohc to Dohc was that you would not be able to hook up to a Consult tool.
You can hook the CONSULT plug up to any 91+ ECU. What car it's in has nothing to do with it.
#15 | |
It should work as I believe the 89-90s were OBD1.
Here is a close up of the female OBD1 plug fromt the Techtom. The car will have the matching male end. |
#17 |
Post Xmas bump
Post Xmas bump
