18RG engine for sale
For sale is a complete early year 18rg engine (Needs assembly) minus carburetors. Email with questions and offers.
Engine was intended to be a period correct replacement for my 1973 Celica RA21 no expense was spared. When built engine should be close to 300HP-ish with an amazing RPM range. Just to give you an idea of my cost pistons alone were 600 and block machining was 400, not to mention having to find the engine. Rare opportunity to own an early twin came Toyota engine that's also a hemi. Price 1200 OBO or 1500 firm with W50 transmission (5 speed) Here is a comparison price for engine with non-performance parts RARE 18R G 18RG Engine Spec Clutch and Flywheel Koyo Radiator Many EXTRAS | eBay Details (Read these) Engine block cleaned and bored to 91mm (done by Yo at Contemporary Auto Machine in HB) Crank has been balanced and polished (Specific measurements are on a tag attached to crank) Also been cleaned by Yo New in the box bearing set for crank New in the box bearing set for connecting rods Stock connecting rods (will need new bushing for pistons, Joel at ToySport has them) Wiseco 91mm piston set (New in box, with all rings etc... High Compression pistons) These pistons were custom designed and ordered by Joel at ToySport. Brand new FelPro gasket set for 18rg Original timing gears and chains Original Aluminium timing cover Multiple oil pans (depending on your configuration there should be one to fit your car, includes pick ups) Early Year 18rg Cylinder Head (has larger ports, that have been ported and polished.) Could use a once over and assembly from Joel Custom ground CamShafts (specs unknown but they are in great condition and recommend using) Original Valves, Springs, seats, etc... Comes with two head covers 1 semi-polished and 1 with the original black matte finish. multiple intakes included (short carb, long carb, fuel injection, etc..) Original exhaust manifold. Original and complete distributor assembly You will have to purchase Spark Plug wires and Plugs Original water pump and housing Original Oil Pump (includes new filter) Original Flywheel Unknown clutch and pressure plate Original Starter Original Alternator Original Fuel pump I'm sure there is more, but that's all I can remember. |
| 18rg, engine, twin cam |
