![]() Join Date: Nov 2003
Ok, I have a 95 Nissan 240sx and it throwing codes 105 and 34.. I just replaced the knock sensor so i believe it is coming on becasue of the other code.
I have already done some researching and there is not that much info on my particular issue. The code stands for the egrc solenoid valve. After investigating and looking at where it was suppose to be located, I believe that on my model and newer; they have relocated it below the intake manifold runner nearest the firewall. I was going through the diagnosis steps in trying to eliminate what the issue could be. Upon checking for continuity between the connecter harness and ecm, they instructed me to check pin # 103 and to find out i do not have a wire/pin running to # 103. I do not know if it is different between the base model ecm and the SE model, I'm assuming not. I was wondering if this could be the issue why I am throwing the code? But then again, I haven't had this issue until recently meaning that it was functioning properly at one point without pin #103. So, I would like to know if anyone else has ran into this problem and how you solved it? Thanks for the help. -kouness
![]() 95 Nissan 240sx: Q45 brake upgrade, v'tund lip |
After looking back at my ecm, I figured that I was looking at it the wrong way. When trying to check the pins, look at it like you are plugging it into the ecu. I figured out by looking at the wire coloring of the plug and pin 103. I believe the wire is blue with a red stripe. I havent really figured it out yet since i work 6 days a week, 9 hours a day, but I will be replacing the egr solenoid valve soon. I believe that code 34 comes on with code 105. if you fix code 105, then it should also fix code 34.
I know that to access it I am going to have to remove the intake manifold.. not something that i am looking forward to.. I will post up my results when i get the chance to.
Sorry to bump an old thread but I'm having both code 34 and 105. Replaced the knock sensor but still having the codes. Did a smoke test and found a big ass leak from the intake manifold. not sure if a leaking manifold would cause those codes to come up
