Ka24de rumbles timing??? Help
Hey wats up let me tell it from the beginning so I have a 92 ka24de was running good I changed the timing chain and guides, after it was all done I started the engine it idle like if it was cam. So I new I had skip a tooth I fix it it idle fine very smooth it felt like it lag power not a lot just a tiny bit when WOT . Also it wouldnt pass smog high nox -_- ). Heres were I think I messed up I tried re adjusting the cams again I check a bunch of puctures of the cams alignment n every thing check out I moved but it looked like the intake side was a little off so I skip another tooth. I put everything back (cold engine) I start the car it starts to rattle I kill it quick within seconds.. at this point im thinking I bent the valves.. so I re do the cams again and hope for the best, it starts right up idle is kinda smooth but slowly kinda sputters. Heres the thing the car runs way better n the power it feels great better than before I try to adjust the dizzy but still rumbles car stays on dosent die..
So my questions are : Are my valves bent? What can cause the bad idle ? Car is stock no mods just a 11lb fidanza flywheel everything else STOCK thanks and I appreciate any help I can get |
![]() Join Date: Feb 2012
bad idle can be caused by a number of things. did you realign the motor to tdc when you were adjusting your distributor? I would look into proper distributor timing first and foremost. iirc the motor is supposed to be 20 degrees shy of TDC (there's a notch in the crank pulley to mark that) as you adjust the distributor... However, your best bet is to check your factory service manual.
