11-18-2009, 09:37 PM | #1 |
S13 Chassis Wiring Master List
Alright guys, you better appreciate this. Hopefully you guys can use this as a good point of reference when you decide to tackle whatever wiring job you may happen to be working on.
I've had an OEM Wiring Diagram from 1988 for the S13 chassis, SOHC, and covers both hatch a coupe models. I'll Work on getting better pictures, but my scanner just isn't big enough for the pages (I'll take it to a copy place to have them scanned, and scaled down) Included in the book is a 7ft, color coded, schematic of the entire harness which I'll also figure out a way to get on here... possibly in a PDF or Zip. Anyways, hope you guys like it, I've never seen another one of these books. Main Body Harness M1 – Time control unit M2 – Headlamp timer M3 – Check connector M4 – Warning chime M5 – Fuse block M6 – Accessory relay-1 M7 – Circuit breaker M8 – Circuit breaker M9 – Ignition relay M10 – Ignition relay M11 – To engine room harness (E101) M12 – To engine room harness (E102) M13 – To engine room harness (E103) M14 – Bulb check relay M15 – Rear window defogger relay M17 – A.S.C.D. clutch switch M18 – To door harness L.H. (D1) M19 – To door harness L.H. (D2) M20 – Driver side front limit switch M21 – Kickdown switch M22 – A.S.C.D. cancel switch M23 – Stop lamp switch M24 – A.S.C.D. main switch M25 – Headlamp retractor switch M26 – Illumination control switch M27 – Front fog lamp switch M28 – Shift lock control unit M29 – Combination flasher unit M30 – Mode door motor M31 – Foot lamp L.H. M32 – O.D. off indicator lamp M33 – Rear wiper and washer switch M34 – Rear window defogger switch M35 – Hazard switch M36 – Radio M37 – Radio M38 – Cassette deck M39 – Cassette deck M40 – Push control unit M41 – Fan switch M42 – Diode M43 – To sub-harness (M44) M44 – To main harness (M43) M45 – Glove box lamp M46 – Glove box lamp switch M47 – To instrument harness (I1) M48 – To instrument harness (I2) M49 – Thermo control amplifier M50 – Heater resistor M51 – Blower motor M52 – Foot lamp R.H. M53 – To E.F.I. harness (F1) M54 – To door harness R.H. (D101) M55 – To door harness R.H. (D102) M56 – To room lamp harness (R1) M57 – Body ground M58 – Intake door motor M59 – To sub-harness (M60) M60 – To main harness (M59) M61 – Door lock timer M62 – Washer warning lamp M101 – Body ground M102 – Lap belt buckle switch M103 – Seat belt switch M104 – Ash tray illumination M105 – Cigarette lighter M106 – Door mirror control switch M107 – Automatic seat belt control unit M108 – Parking brake switch M109 – A/T device M110 – Shift lock solenoid M111 – Door switch L.H. M112 – Automatic seat belt motor assembly L.H. M113 – Body ground M116 – Body ground M117 – Rear speaker L.H. M118 – Rear side marker lamp L.H. M119 – Rear combination lamp L.H. M120 – Rear combination lamp L.H. M121 – Back-up lamp L.H. M122 – Rear wiper amplifier M123 – License lamp L.H. M124 – License lamp R.H. M125 – Body ground M126 – Luggage room lamp switch M127 – Back-up lamp R.H. M128 – Luggage room lamp M129 – Rear combination lamp R.H. M130 – Rear combination lamp R.H. M131 – Rear side marker lamp R.H. M132 – Fuel tank gauge unit M134 – Rear speaker R.H. M135 – To back door harness (D501) M136 – To back door harness (D502) M137 – To back door harness (D503) M138 – Automatic seat belt motor assembly R.H. M139 – Door switch R.H. M140 – Trunk room lamp switch M141 – Trunk room lamp M142 – High-mounted stop lamp M143 – Rear window defogger M144 – Rear combination lamp L.H. M145 – Rear combination lamp R.H. M146 – A.B.S. control unit M147 – Body Ground M148 – Rear sensor Engine Bay Harness E1 – Windshield wiper motor E3 – A.S.C.D. actuator E5 – Rear washer motor E6 – Front washer motor E7 – Washer fluid level switch E9 – To E.F.I. harness (F8) E10 – To E.F.I. harness (F9) E11 – To engine room harness no.2(E201) E12 – Inhibitor switch E13 – Revolution sensor E14 – Inhibitor switch E15 – To solenoid valve sub-harness E16 – Relay box E17 – To engine room harness no. 2 (E202) E18 – To engine room harness no. 2 (E203) E19 – To engine room harness no. 2 (E204) E20 – Body ground E21 – Low-pressure switch E22 – Battery E23 – Battery E24 – Body ground E25 – Clutch interlock relay E27 – Front side marker lamp R.H. E28 – To front fog lamp sub-harness (E51) E29 – Headlamp R.H. E30 – Headlamp motor R.H. E31 – Front combination lamp R.H. E33 – Horn-high E34 – Condenser fan motor E35 – Horn-low E36 – Headlamp motor L.H. E37 – Headlamp L.H. E39 – Front combination lamp L.H. E40 – Front side marker lamp L.H. E41 – Body ground E42 – Relay box E43 – Dropping resistor E44 – Compressor E46 – A.I.V. control solenoid valve E47 – Brake fluid level switch E50 – Windshield wiper amplifier E51 – To engine room harness (E28) E52 – Front fog lamp R.H. E53 – Front fog lamp L.H. E54 – Front wheel sensor L.H. E55 – Body ground E56 – Actuator E57 – Wiper amp. E58 – A.S.C.D. actuator E101 – To main harness (M11) E102 – To main harness (M12) E103 – To main harness (M13) E105 – Clutch switch E106 – Key lock solenoid E107 – Key Switch E108 – Ignition switch E109 – Combination switch E110 – Combination switch E111 – Horn switch E112 – Steering switch E113 – Windshield wiper and washer switch E114 – To E.F.I. harness (F3) E115 – To E.F.I. harness (F4) E116 – To E.F.I. harness (F5) E117 – A/T control unit E118 – A.S.C.D. control unit Engine (E.F.I.) Harness F1 – To main harness (M53) F2 – E.C.C.S. control unit F3 – To engine room harness (E114) F4 – To engine room harness (E115) F5 – To engine room harness (E116) F8 – To engine room harness (E9) F9 – To engine room harness (E10) F10 – F.I.C.D. solenoid valve F11 – A.A.C. valve F12 – Injector no. 4 F13 – Air regulator F14 – Injector no. 3 F15 – Pressure regulator control solenoid valve F16 – S.C.V. control solenoid valve F17 – Exhaust gas sensor F18 – Injector no. 2 F19 – Injector no. 1 F20 – Engine ground F21 – Crank angle sensor F22 – Engine temperature sensor F23 – Thermal transmitter F24 – Throttle valve switch F25 – Throttle sensor F26 – E.G.R. control solenoid valve F27 – Air flow meter F28 – Tacho resistor F29 – Condenser F30 – Ignition coil F31 – Power transistor F32 – Front wheel sensor R.H. Lower Engine Harness (A/T) E201 – To engine room harness (E11) E202 – To engine room harness (E17) E203 – To engine room harness (E18) E204 – To engine room harness (E19) E205 – Battery E206 – Power steering oil pressure switch E207 Alternator E208 – Oil pressure switch E209 – Starter motor E210 – Exhaust gas temperature sensor E211 – Vehicle speed sensor E212 – Back-up lamp switch E213 – Neutral switch E214 – 5th position switch Instrument Panel Harness 11 – To main harness (M47) 12 – To main harness (M48) 13 – Head-up display control unit 14 – Combination meter 15 – Combination meter 16 – Combination meter 17 – Combination meter 18 – Combination meter Door Harness L.H. D1 – To main harness (M18) D2 – To main harness (M19) D3 – Door speaker D4 – Door speaker D5 – Door Mirror Motor D6 – Power window regulator D7 – Power window main switch D8 – Power window amplifier D9 – Door lock actuator D10 – Door lock switch D11 – Door latch switch R.H. D101 – To main harness (M54) D102 – To main harness (M55) D103 – Door speaker D104 – Door speaker D105 – Door mirror motor D106 – Power window regulator D107 – Power window sub switch D108 – Door lock actuator D109 – Door lock switch D110 – Door latch switch Rear Hatch Harness D501 – To main harness (M135) D502 – To main harness (M136) D503 – To main harness (M137) D504 – Rear window defogger D505 – High-mounted stop lamp D506 – To rear wiper sub-harness (D551) D507 – To rear wiper sub-harness (D552) D551 – To back door harness (D506) D552 – To back door harness (D507) D553 – Rear window wiper motor Roof Harness (lamp and sunroof) R1 – To main harness (M56) R2 – To sun roof harness (S1) R3 – Spot lamp R4 – Interior lamp R5 – Interior lamp R6 – Interior lamp R8 – Automatic seat belt front limit switch S1 – To room lamp harness (R2) S2 – Body ground S3 – Sun roof switch S4 – Slide relay – open S5 – Sun roof motor S6 – Safety relay S7 – Slide relay – close S8 – Safety limit switch EDIT: Notice the last picture....Engrish at it's best, "Room Ramp".
Tags |
diagram, wiring, wiring body harness s13 |
