SMIC to FMIC = no boost.... HELP!!
i just converted my sr20det side mount to a front mount but now i cant hit boost. It runs fine and i have vacuum. Any ideas what it could be???
![]() Join Date: Dec 2006
Boost leak = Loose Couper
Check all pipe connections
Yea 'tight' doesn't mean they don't leak. Build a boost leak tester and test it. Search how to do it.
I got a leaky coupler that I can't get to seal. It's fucking garbage.
@UpshiftEngineering |
SOo, i'm pretty sure its has something to do with the wastegate... i pulled the line connected to the Wastegate and was able to get boost but i didnt attempt to hit my full boost because i read that it could have negative effects on the engine. what do i do now?
ALSO, when i hit 3100 rpms or above, there's a loud whoosing sound (someone said its my wastegate staying open?) should i just replace my wastegate? or can i do something about it?
![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
Hey,
irun240sx, where are you getting your vacuum pressure from for the wastegate? On the hot side pipe?
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
