![]() Join Date: Jun 2006
SR20DET vacuum line woes
Hey guys I need some help. I have a blacktop Sr20det that I am swapping into my Datsun pickup. I am currently dealing with the vacuum/boost lines. On the throttle body, there are two upper nipples. I have the left one going to the FPR and tee’d with my boost gauge. The right one goes to my BoV. It seems I only have vacuum at those ports. My bov will stay wide open during idle and when I rev it, it closes. My boost gauge will only read in vacuum and never see boost. What can be causing the vacuum only issue? Thanks
![]() lexus baby |
are you looking for boost with no load? it wont pickup much while you are sitting there...the engine is in vacuum when idling and your BOV is designed to open when off throttle...sounds like your spring may be to soft if its opening just sitting there tho as its supposed to open whenever you let off the gas...what boost are you getting when you have a load and do you have a way to test the guage as i have seen many fail over the years...
This is a new swap so all parts I have are new. At idle, my tail bov is wide open. Also the same when I bolt on the Hks. I’ve driven around and it still shows no boost. I will only see vacuum and 0psi. My gauge is innovate motor sports scg1. I believe it used a map sensor. I have that tee’d into the fpr line
![]() lexus baby |
http://www.frozenboost.com/bov-a-bov.html what are your compression numbers? secondly are you hearing the turbo spool while you accelerate or does it just barely function?
How can I tell if my turbo is spooling? This is a brand new s15 t28. When I first started it up after my swap, I could hear it spool. But now I don’t hear anything. What should I check?
![]() lexus baby |
Nvm it is working. Just strange that during low speed driving in the parking lot, it never shows boost. Only when I drove it on the streets did I hit boost. 7psi is the norm with just the wastegate correct? I still question why my Tial BoV stays wide open when idling? It causes the engine to idle like crap and want to die.
![]() lexus baby |
