Freshly built KA24DE with Tranny
For Sale:
2.4L (KA24DE) rebuilt engine/Tranny/ECU/Stage one clutch: I bought the car with the engine running prefect, then the timing chain busted the timing chain guide. The car was kept in a garage after that while the engine was rebuilt by my father who has been in the auto business for 50+ years. Owns his own garage and did the work to the engine for me. Everything that was replaced was only for purposes to ensure that the engine ran again and had no issues. After finishing the engine I decided that I was going to transplant something else into this car. The engine hasn't been started since the rebuild. There is no warranty on this engine, it is sold AS IS. If any questions arise in the process of inquiry I will have my father available to answer questions also. Though most of it is straight forward as for the parts we replaced. Parts/work list: Flywheel Turned Stage One Kit- Kevlar Head Planned- 6 thousands- Tested Crank Polished Timing chain idler gear – heli coiled New timing chains and guides New oil pump and front housing New belts and hoses New rings and bearings- clevlite All new gaskets Transmission has had no work done to it, but did work prior to engine failure ECU comes with wiring and is uncut 1900 OBO Text for pictures 5six3-5nine9-one5zero6 Last edited by Theworm; 06-24-2013 at 09:11 PM.. Reason: edit |
| ka24de 5 speed manual |
