#901 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Made a YouTube clip for ya homie. Hope this helps https://youtu.be/EDD46CZYVZM Sent from my iPhone using Tapatalk Pro
#902 |
![]() Join Date: Oct 2009
Trader Rating: (38)
Anyone using a twin disc clutch with the mazworx cd009 kit. What sleeve for the throw out bearing are you guys using ? I have a exedy twin disc. Not quite sure if the stock 30501-K0404 24mm S13/S14 works with it since it's a twin disc.id appreciate any feedback thanks
#903 |
![]() Join Date: Sep 2012
So, I got a question for everyone. I'm about to order my adapter kid from my jz/cd swap.
Measurements: a340 Bellhousing 14 3/8" exterior diameter (top to bottom), 4 3/4" depth; 13" inside diameter, input shaft is centered @ 6.5" CD009 16" exterior diameter (top to bottom), 6 3/4" depth (to second rib where cut is made); 13 1/4" inside diameter, input shaft centered @ 6 5/8" Assuming the no-cut adapter ring is 1/2" and the "cut kit" adapter flange is 1.5", the overall length would be shorter with the cut kit (1.5"), while also having about an inch extra ground clearance, and less firewall bashing. Is it worth the extra money converting to an internal slave set-up needed for the cut kit since my CD is external with a new slave?
@jz_2tone |
#904 | |
![]() Join Date: Mar 2009
For what it's worth you have to use a shorter sleeve with the OsG twin disc, the factory sr sleeve is too long. |
#905 | |
Twin Disk TOB Sleeve Standard S chassis fork (I was told my Maworx you cannot use the upgraded steel fork or pivot ball) And twin disk TOB (part number Koyo/Nissan 30502-14601) I think the TOB and sleeve are essentially universal across a majority of the most of the twin plates |
#906 | |
Trader Rating: (38)
What about the nismo pivot ball . Looks identical as the stock sr one from a glance |
#908 | |
Trader Rating: (38)
Awesome thank you ! So far from what I've gathered for the mazworx bellhousing kit and exedy twin disc clutch I use the OEM sr20 24mm sleeve? |
#909 | ||
The Mazworx bellhousing is designed around the SR bellhousing dimensions, so any clutch parts for the regular sr 5-speed trans are cross compatible and that's the parts you would use for aftermarket clutches.
I've posted all the bearing/sleeve info for ORC twin discs before, pretty sure its the same as OsGiken as well.: Quote:
Generally the twin disc stack height is taller than a single disc and requires a shorter sleeve. I'd be surprised if their twin plate is the same height as a single. |
#910 |
Trader Rating: (38)
So yea contacted exedy and they said it uses the stock oem sleeve from an sr20det which would be a 24mm sleeve and just pair it with thier tob provided . Def would have though it would of been a shorter one like said since it's for a twin disc . Looks like I'll have to mock it up and see how everything is lining up
#911 |
Guys I?m running Redline MT-85 fluid and I get some nasty shifts when the trans is cold but it shifts great once it finally warms up. You guys have the same experience? What?s everyone using?
Also with a the brand new trans do you guys change the fluid after a few miles or nah? Sent from my iPhone using Tapatalk Pro
#912 |
S15 6spd maybe but the 5spds never had that low of gearing in the differential.
![]() 95 240sx RB20 415whp 91 Nx2000 VVL yo |
#913 |
What?s up dudes.. Newbie, but FAR long time lurker of the forums, just here to shed some info that may or may not have been covered before.
Starting off, the Factory CDXXX to End of service cover is 28? With the collins A340, it?s the same 28?. Maybe useless to know, but that means the sandwich plate Adaptor adds about 1/2? to the total length. I?m running factory flywheel M/T 3RZ bolts, this is because the Collins kit comes with some trash nonflanged grade 10.9 bolts. The 3RZ are 12 point, and high grade with factory thread locker cost: $20 from my local Yota dealer. The collins Full Kit comes with some trash Ebay clutch setup, so I opted for a Southbends Clutch, and my Slave cylinder is a factory GM part, as far as my clutch lines and Bleeder valve, I went with the ISR T56 remote kit (comes with Wilwood MC setup). As far as the shifter goes, many probably know by now the collins shifter is trash, I made the mistake of buying it, and I?ll post a vid of how suicidal the shifts are. Collins Shifter: https://youtu.be/eolBShUOVfY The Diff I?ll be using is an Early model Q45 6 bolt diff, with z33 axles. This diff is a similar ratio as the factory 350z rear diff, but complete bolt on for S13s. I?ve bought both my CD009 Transmissions for $200, the trick is to look for 05? G/Z transmission, most of these are marked CD#1 on the casings. This doesn?t mean they are CD001 or CD008. Nissan recalled some transmissions for the syncros, and replaced the transmissions with Early CD009s. I?ve confirmed my ?Gold? transmission is in fact a true CD009 with ConceptZMotorsports. But it was for sale as a CD001, and I?ve seen others posted for sale the same way. Just a good thing to keep in mind while looking for them. Sorry for longish post, but hopefully something is useful to someone. |
#914 |
Whats up Peeps, just a Super Noob floating in, but long time lurker. Here to share useless info, and my build so far.
So to kick things off some info... Which maybe useful to someone out there. Stock uncut CD009 Bellhousing-Service tunnel distance: 28" ![]() Collins A340/CD009 Bellhousing-Service cover: 28" ![]() If you run the sandwich plate i guess expect about 1/2" more, so the shifter will be moved further rearwards. Okay, so the Collins kit is OK, but he sends it with garbage nonFlange 10.9 Flywheel bolts. Due to the flywheel thickness and Crank hole depth, this makes it kinda a pain to find bolts for, you can cut ARPs if you want. I went with OEM 3RZ M/T Flywheel bolts, all 8 from my local dealer for $20. Shifter is Trash as well, i'll be selling mine because im scared to Money Shift with it, i'll post a vid of how suicidal the shifts are and Reverse is. I'm running a factory T56 Slave, with the ISR T56 relocation kit from Enjuku Racing, this kit comes with a Wilwood MC as well. AS well Collins sends an Ebay clutch with his kit, but marks it up as a premium. I opted for a SouthBends DxD clutch. ![]() ![]() ![]() ![]() So for peeps looking to ball on a budget like i did, i bought both my CD009's for $200. Just look for 05' Transmissions, early 05' were recalled for synco issues, and replaced with Early Edition CD009's, these transmissions only have CD#1 on the casing, and other wise thought of as CD001's. My "Gold" transmission was confirmed by ConceptZmotorsports as a true CD009 by the vin plate, and the CD#2 in the input shaft plate. AS for a decent diff, i'll be running an Early Q45 6 bolt diff, with Z33 axles. This is a direct bolt in for an S13, and is the same Ratio as a factory 350z to match the trans. This car is being built as a cruiser for me and my girl. Building an 800hp 2J/CD for my S14 As far as my build, its a 1JZ VVTi, with the Collins A340 setup, in a 91 Hatch S13 ive owned since i was 15 flipping burgers Fast Food. |
#915 | |
![]() Join Date: Oct 2013
Need aftermarket parts? PM or DM me competitive pricing! [email protected] |
#917 | |
Source: factory service manuals, verified with JDM differentials. My S14 5spd 3rd is long af, gets me to 80-90 ish. |
#918 | |
I know some of the older trans pre-CD009 were notchy simply due to the unrevised syncro setup on those (double cone vs triple cone in CD009). A lot of people just call any Z33 trans a CD009 not realizing the early models kinda sucked. Last edited by LoSt180; 05-13-2020 at 01:04 PM.. |
#919 | |
#920 |
#921 | |
https://www.amsoil.com/p/manual-tran...be-75w-90-mtg/ |
#922 |
So you're telling me, if I buy a JDM S14 SR20DET differential, it will have a 3.69 gear ratio?
#923 |
#925 |
#926 | |
Good to know. I?ve got a Kaaz 2 way in mine currently that I don?t want to lose. Just want better gearing for highway cruising Sent from my iPhone using Tapatalk Pro
#927 |
Confirmed. 350/370 gearboxes are loud lol. Its only obnoxious because most if use drive a tin can for a vehicle with lack of sound and heat insulation lol.
I added some heat/sound insulation and will probably add more later down the line |
#928 |
True story. Oddly enough mine has actually quieted down as I?ve put some miles on it. Mine was factory new using serialnine bell housing and comp clutch stage 4 clutch.
#929 | ||
I just got the engine (2JZ) and trans (CD009) installed today, however, the engine brackets won't quite sit right on the mounts. Anyways, I think it may be interfering in the trans tunnel, where did you bash? |
#930 | |
Yeah I don?t remember off the top of my head but I got some hardware from ACE that worked. Basically bashed along that piece that goes around the tunnel (sheet metal tack welded on) just mash both side and the top flat. Should give you enough clearance. I did install my trans mount to make sure those holes didn?t shift though with all the bashing. Good luck Sent from my iPhone using Tapatalk Pro
