Just bought a 2006 BMW M5 and I need money to buy some new wheels. I simply do not have any more time to work on the Nissan.. Car is well maintained and always garaged. Spent well over $16K on parts and replacements alone. A lot of time and energy has been spent building this car and I'd hate to see it go.
Please no flaming, I know to some you this sort of car is NOT your cup of tea with the rotas with nismo stickers and S15 front end but please keep your negative comments to yourself.... if you do post negative comments you admit to the entire forum that you're a retard and that you can NOT read. FOR SALE: 1992 Nissan 240sx SE S13.5 Clean Title 144,XXX miles Engine: Redtop SR20DET with approximately 65k miles Oil Changed every 3,000 miles with Mobil 1 Fully Synthetic Oil Has all A/C lines plumbed, just needs to be recharged Brand New seals on Front, Rear and Transmission Brand New Injector O-Rings and Seals Brand New Coolant Temp Sensor Brand New Water Pump Brand New NGK Iridium Spark Plugs Exedy Stage 1 Clutch Mishimoto Starter Godspeed Radiator Greddy Front Mount Intercooler Greddy Hot and Cold Pipes Greddy Oil Pan Greddy Type RS Blow Off Valve Greddy Replica Intake Manifold Apexi Exhaust Control Valve Apexi Turbo Timer K&N Air filter Cartridge Circuit Sports Teflon Intake Manifold gasket Odyssey PC680 Battery Engine Torque Damper Circuit Sports Downpipe Circuit Sports Turbo Extension Pipe Nismo 3" Test Pipe (Cat Delete) Nismo Thermostat Walbro 255 Fuel Pump Z32 Fuel Filter Brand New Clutch Master Cylinder Brand New Slave Master Cylinder Custom 3" Piping Dual Tip Exhaust system Exterior: Brilliant Silver (K-23) three stage paint job S15 OEM Headlights S15 Spec R front Bumper S15 OEM Foglights S15 OEM Metal Hood S15 OEM Metal Fenders (converted) S15 OEM Front Emblem S15 OEM Spec R Side Emblems S13 OEM Kouki Side Skirts S13 OEM Kouki Rear Valences S13 Three-Piece Kouki Spoiler S13 JDM Kouki Tail lights Ebay Roof Spoiler Nismo Side Markers Carbon Fiber Door Pillars Custom Z-Pillar covers Front+Rear Fenders Professionally Rolled and Pulled Interior: S15 OEM Front Seats S15 OEM Steering Wheel Nismo GT Duracon Shift Knob Nismo Replica Short Throw Brand New Carpet Custom Suede Roof Liner Custom Suede Door Panels Custom Suede Shift Boot Custom Suede Glove Box Custom Suede Rear Privacy Cover Wide Angle Broadway Rear View Mirror Apexi Turbo Timer Autometer Boost Gauge Sony Stereo Head Unit Suspension+Wheels: 18x9.5 +20 Rota P45 Wheels - Flat Black with Nismo Stickers 215/40/18 Achilles Tires FRONT - BRAND NEW 100% tread life 225/40/18 Achilles Tires REAR - BRAND NEW 100% tread life Nismo Power Brace Muteki Titanium Lug Bolts 5mm Spacers on Fronts 25mm Spacer on Rears Genuine JDM Nissan Front Strut Tower Bar Ebay Rear Strut Tower Bar KTS Coilovers Circuit Sports Tension Rods Brand New OEM Tie Rods Brand New Steering Rack Bushings Brand New Steering Rack Boots Brand New Front Ball Joints Brand New FLCA Bushings Energy Suspension Rear Subframe Insert Bushings S14 VLSD (low miles) Brakes: Brembo EVO Front Calipers in Custom Silver Brembo Front Slotted+Cross Drilled Rotors Brembo Rear Slotted+Cross Drilled Rotors Brembo Front Brake Pads Duralast Rear Brake Pads Z32 Brake Master Cylinder The bad: - RPM Gauge stopped working. It was working prior to replacing the dash but i'm sure I just forgot to wire it back up. - Stereo head unit is fried. - Found out the main A/C line had a leak. I bought a new line to replace it. Just needs to be installed. - Installed a new short throw shifter and for some reason everytime I shift at high speeds it grinds. I assume it's the short throw that causes it, but worst case scenario lets just say the tranny is going bad? All simple fixes. Some of you may be thinking why I just don't go ahead and fix all these.. well to simply put, I just don't have time as I live in LA and the car is in San Diego. I have lowered the price of the car to sell accordingly to reflect these little hiccups. Looking to get $11,500 o.b.o. Price update: $10,000 Car is located in San Diego, CA. If you have any questions please don't hesitate to ask me through Private Message. If you're serious about the car, you may text me at 858-361-2039. Cash and bank cashiers check accepted only. No installment payments or personal checks. Thanks for looking. -Joe ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedForce_350Z; 09-19-2011 at 11:59 AM.. |
![]() Join Date: Jun 2010
I haven't even seen the car yet because my Internet is loading the pictures so slow...But i can still tell this is clean as F*CK just by the quality of the first quarter of every picture haha.
Shitty cars = Shittier camera's and photography Clean cars = Quality camera's from good photographers Free bump and GLWS! |
![]() Join Date: Nov 2004
Very nice car. Totally knew you didn't have real LMGT4's though just by looking at pics. None the less, I'd trade mine for yours anyday.
KA-T ORG-Function over Flush
Those are one off pieces i made and cannot be found anywhere else. There are however, z32 type c pillar covers out there, but look like butt when installed. Oh yeah, good luck finding them. I do believe they are a discontinued item. I can reproduce them to folks for a good chunk of change if need be. Lmk if there are any interests!
#19 |
#25 |
Added a few things I found wrong with car listed above. Nothing major. Also lowered/updated the price to sell fast.
Thanks again for all your compliments guys, I would hate to see this car go as it is just a beauty and I don't have time to work on it anymore. |
