Old 06-30-2009, 06:57 PM   #931
Wake
Wake's Avatar
Originally Posted by Teambadrun View Post
td06-20g is more sized to a gt2835 HKS aka 3071r
the hks gt-rs = 2871r 52t .64
just clearing things up
are you saying the hks is more worth it than the garret?
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 06-30-2009, 09:34 PM   #932
deukalionS14
deukalionS14's Avatar
deukalionS14 is an unknown quantity at this point
I'm not sure about "worth it" but they sure are more expensive! I wouldnt mind getting the TD06-20g though.
want to be in the 500whp club by the end of next year!!!
deukalionS14 is offline   Reply With Quote
Old 07-05-2009, 10:11 AM   #933
deukalionS14
hey, im thinking about buying a new intake cam. as as i keep the lift the same the brand shouldnt matter right?
the HKS step 1s have 10.5 lift but i want to move up to a 264 duration cam from another brand with the same lift.
any input on this would be great. thanks!
also, what would be the benifits of going with the ATP external set up? does anyone have any reviews on this so far?
Old 07-09-2009, 06:39 PM   #934
YoungGun
YoungGun's Avatar
Hey guys can you recommend a wastegate actuator that I can use with a gt2871, my aem boost controller sucks and would rather control boost with the actuator.
Thanks in advance.
Old 07-09-2009, 08:09 PM   #935
usdm180sx
usdm180sx's Avatar
Thanks in advance.
Try HKS EVC or Blitz Dual SBC. Both are really stable.
-Norm!
Old 07-11-2009, 12:43 AM   #936
JacksonBrown
JacksonBrown's Avatar
JacksonBrown is an unknown quantity at this point
The HKS Wastegate accuator for S14SR comes highly recommended for what you're inquiring about.
JacksonBrown is offline   Reply With Quote
Old 07-11-2009, 10:28 AM   #937
deukalionS14
yeah, i have the blitz unit. its really good and makes me smile!! but the hks actuator is good as well
Old 07-12-2009, 08:11 PM   #938
Osmosis
Osmosis is making a name for him/her selfOsmosis is making a name for him/her self
Some more tinkering got this out of her. The super low TQ bugs the hell out of me. Gonna throw some cam gears on her and have them degree the cams (bc 264's) and see if that helps.
rods
pistons 8.5/1 .5mm over
bc stage II 264 in/ex cams
springs
retainers
RAS
greddy IM
gt2871r .64
740cc injectors
enthalpy tune
z32 maf
tial 38 external gate
18psi
Osmosis is offline   Reply With Quote
Old 07-13-2009, 09:23 AM   #939
slider2828
slider2828's Avatar
I think torque has a lot more to do with timing and rather than degreeing in my opinion
Turn and Burn!
Old 07-13-2009, 09:48 AM   #940
OBEEWON
OBEEWON's Avatar
I want to know about the external option too. Anyone?
Old 07-18-2009, 12:05 PM   #941
deukalionS14
well I finally collected my GReddy IM, Q45 throttle body flange, and my Q45 throttle body so i'm taking the car down to Mike at Canyon Racer to have the welding and install done!!
hopefully that will let me boost to 18psi and actually see a change in power!!!!
Old 07-19-2009, 04:29 PM   #942
180Sil
180Sil will become famous soon enough180Sil will become famous soon enough180Sil will become famous soon enough180Sil will become famous soon enough
To all 2871 .64 turbo user on this thread, at what RPM do you hit full boost?
From what I read this turbo should be hitting full boost at 3800rpm but mine don't hit full spool until 4500rpm. I've tried lower boost setting 12, 14, and 16psi and it's the same thing. This is on a redtop sr20det built motor and it's not the clutch cause there's no slipping the power just climbs all the way to redline but not until 4500rpm.
any thoughts?
180Sil is offline   Reply With Quote
Old 07-19-2009, 06:15 PM   #943
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
any thoughts?
sounds about right,what did you expect??i has alot to do with your supporting mods.the biggest contributing factors being the duration of your cams and wether or not you are using an aftermarket manifold.
" NEO VVL BABY FTMFW!"
Originally Posted by shagspeed
Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines
ross.cottrill is offline   Reply With Quote
Old 07-19-2009, 06:16 PM   #944
ross.cottrill
intake manifold that is ,sorry...
Old 07-19-2009, 09:25 PM   #945
180Sil
I have the BC stage 2 264 cams and a Greddy Intake manifold. i'm trying to get full spool at 3800rpm. I have a friend who has a HKS gt2540 and that got full spool at 3500rpm, I kinda want that turbo.
So you're saying that the BC 264 and Greddy IM is that reason I spool so late? So even if I switch over to a S15 OE turbo it would still spool late?
Old 07-20-2009, 02:33 AM   #946
2forty
2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of2forty has much to be proud of
intake manifold should make a noticeable difference in spool. as well as cam duration. an s15 turbo would spool slower than it would compared to if you had stock IM and EX mani and cams
TEAM SKIDMARKS Carbon black S13 SR Coupe
2forty is offline   Reply With Quote
Old 07-20-2009, 10:11 AM   #947
slider2828
slider2828's Avatar
Come on guys, a aftermarket intake manifold actually slows down the spool of the turbo. You lose low end and gain high end. THat is just how it is. Duration, manifold and timing makes the biggest difference in spool time. A 2871R is going to spool slower than a gt25 frame, but its going to make more power.... people actually need to read this thread not just ask questions some times. lol
Turn and Burn!
Old 07-20-2009, 10:25 AM   #948
usdm180sx
usdm180sx's Avatar
Originally Posted by chris300zr View Post
this makes me happy to see since im running a very close setup to yours except im using P-FC. what size injectors do you run?
I went with the nismo 740cc's.
Nice summary. I never thought of it that way. I had the greddy im too and iirc i hit full boost around 3500-4000 rpm. The gt-rs spooled pretty fast. It was always cool to hear the turbine shaft spinning after the car turned off b/c of the ballbearings
-Norm!
Old 07-20-2009, 11:37 AM   #949
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
Are you talking about this thing?
Seems like the housing point straight at the shock tower though.
Homer_Simpson is offline   Reply With Quote
Old 07-20-2009, 11:53 AM   #950
drftmark
drftmark's Avatar
drftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura about
^damn or the steering shaft.
I already have a hard ass time swapping turbo's with the steering shaft in the way.
someone should get it and test it out.
drftmark is offline   Reply With Quote
Old 07-20-2009, 05:46 PM   #951
usdm180sx
usdm180sx's Avatar
I am really curious too. The tial mv-s is a new slimline wg. Hopefully it will fit
-Norm!
Old 07-21-2009, 09:29 AM   #952
slider2828
slider2828's Avatar
Yeah I wanna get it and the slimline v38mm is like 2.5 inches tall, I think I measured and it clears no problem.... Just need the funds. I priced it out it. The frame is 350+tial which is another 200 so its like 600 with taxes and all the bs. Dunno if it is worth it as 2871R setups especially on my car spools up fast enough.... Its pretty pricey and a LOT of work....
Turn and Burn!
Old 08-11-2009, 10:18 AM   #953
2Slow40
2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute
I got a question for you T2871r gurus.
My T25 is blown but I have a T2871r sitting around. Can I take the stock wastegate off my T25 and run it on my T28 ? The T28's wastegate is modified for 15psi, so I dont want to use that.
I also have a stock hg, if I keep it at 7psi will I still risk blowing my headgasket if I don't track the car? I want to do this just so I can get my car running while I wait for a new T25.
2Slow40 is offline   Reply With Quote
Old 08-11-2009, 10:46 AM   #954
slider2828
slider2828's Avatar
The T2871 is not adjustable (lengthen the rod)? I don't think the T25 will fit from what I remember....
Stock headgasket is paper bro.... it will blow from overuse.... F.. Paper gaskets...
Turn and Burn!
Old 08-11-2009, 10:49 AM   #955
2Slow40
That's what I was thinking, damn. I wasn't planning on running the T28 for long, maybe a week at the most just so I can get around. Back to the drawing board I guess. .
Old 08-12-2009, 12:32 AM   #956
slider2828
slider2828's Avatar
Well if t28 for a week dun worry about it... nothing is going to happen, but if you going to track it, paper gaskets ain't going to be happy.
Turn and Burn!
Old 08-12-2009, 10:32 AM   #957
Soup Nazi
Soup Nazi's Avatar
Soup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond reputeSoup Nazi has a reputation beyond repute
I was all about getting the 2871R. 86, however I'm really leaning towards the 3076R .63
If I do go this route, hopefully I won't be disappointed...
Originally Posted by sil80forme View Post
Edited u guys suck
Nissanparts.cc... Enjuku-Racing
Ever bought anything from me?
Leave a review
#/f/showthread.php?t=200877
Soup Nazi is offline   Reply With Quote
Old 08-12-2009, 12:32 PM   #958
KoukiMonsta
KoukiMonsta's Avatar
for u guys using this turbo on a redtop what oil return do u use. im in the process now and the piece i have from my old gt2510 doesnt fit. someone pls help this is my only car.
Old 08-13-2009, 10:06 AM   #959
slider2828
slider2828's Avatar
I just use taka or circuit sports lines. get new lines so you don't strip the block. Also make sure you are using a restrictor on the oil line because the new lines don't come restricted and risk blowing your turbo...
Turn and Burn!
Old 08-13-2009, 10:06 AM   #960
slider2828
slider2828's Avatar
Make sure its top mount and not weak ass bottom mount. Look up steveshadows, he has one that is running 400WHP on a Dynodynamics... Probably the best tuner around...
Turn and Burn!
