Old 11-27-2015, 10:04 PM   #31
drftx
drftx's Avatar
Trader Rating: (42)
drftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant futuredrftx has a brilliant future
Feedback Score: 42 reviews
Send a message via AIM to drftx
Did some black friday things
Origin fenders, Origin carbon canards, s14 LCA for the subframe swap, some aero mirrors and Toshio Maeda for Supreme shirt
drftx is offline   Reply With Quote
Old 11-28-2015, 09:11 PM   #32
Visionshift
Visionshift is an unknown quantity at this point
Looking good Alan! Keep it uppp
Visionshift is offline   Reply With Quote
Old 12-17-2015, 09:16 PM   #33
izzy-
izzy-'s Avatar
izzy- is an unknown quantity at this point
izzy- is offline   Reply With Quote
Old 04-04-2016, 05:43 PM   #34
drftx
drftx's Avatar
Trader Rating: (42)
Nothing really new just waiting on some bits and pieces
My buddie with his rb25 neo swapped 32
Got some s14 front LCA and s14 axles
Grabbed some s14 knuckles as well painted it silver like my diff
Grabbed some of these HKS garage moon power matts!
Had some time to fit the rear bumper to glass it together
Glassed it together and sanded this beast shits hard work
Sanded it down with 40, 80, 120, and 400
Rear and front are DONE
Old 04-05-2016, 08:58 AM   #35
Gingersmurf
Whats up with the big hex bolts in the rear bumper there? was that just a metal backing plate while you were laying the fiberglass?
either way, nice work
Old 04-05-2016, 12:13 PM   #36
drftx
drftx's Avatar
Trader Rating: (42)
Good eye! I mounted the bumper on the car and had 4 thin metal plates. Drilled 2 holes each side and put bolts through it to hold the bumper straight and together. I used foil tape on top of that and glassed the inside of the bumper. I also put resin in the front before I used body filler. Its my first time doing this after watching some youtube videos. Turned out pretty good sanding just sucked.... I did the same for the front and sideskirts
Old 04-05-2016, 01:09 PM   #37
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
Random question:
Not that it was uber durable to begin with, but after re-glassing is it a weak spot that you have to be careful of, or is it stronger now then before? I.e. if you bottom out or scrape will it split right up the middle?
Regardless that aero is gorgeous and really unique in a sea of now obligatory r32's.
sidewaysil80 is offline   Reply With Quote
Old 04-05-2016, 01:54 PM   #38
drftx
drftx's Avatar
Trader Rating: (42)
Originally Posted by sidewaysil80 View Post
Random question:
Its actually stronger on the spots where I glassed it. I accidentally dropped the car on the skirt and landed where i gladded the skirt. It bounced back and chipped the body filler thats it hahs. But I used resin on both sides to make it stronger.
Old 04-05-2016, 01:55 PM   #39
drftx
drftx's Avatar
Trader Rating: (42)
A trick to use to is fill the bottom part of any aero with "the great stuff" makes it stronger and absorbs shock.
Old 04-05-2016, 08:45 PM   #40
Supraman127
Supraman127 is an unknown quantity at this point
Damn.... so you finally paid off the car huh?
Supraman127 is offline   Reply With Quote
Old 04-11-2016, 07:10 PM   #41
drftx
drftx's Avatar
Trader Rating: (42)
Buddy of mine cut and extended my LCA's still gotta cut out the bump stops
It was kinda nice out and the front shocks were blown. Swapped out the fronts for STANCE coils and relocated the harness as well as putting the front fenders on.
This stupid fender liner was a bitch I was to lazy to take the wheels off
Got that thing outta the way
In you go!
Blown ass apexi shocks VS STANCE
Stay tuned.
Old 04-13-2016, 08:25 AM   #42
tuzzio
tuzzio's Avatar
the attention to detail on the LCA's is amazing.
Old 04-13-2016, 08:45 AM   #43
Almighty So
Almighty So's Avatar
Misleading thread title op seems perfectly aware of what he's doing
Old 04-17-2016, 08:00 PM   #44
drftx
drftx's Avatar
Trader Rating: (42)
Nothing too crazy just a small touch. The r32 did not have the trim around the key cylinder so I picked this one for a 180 off of ebay. Came with the "JDM" key ring!
A lot of trimming was required haha
End result is pretty cool!
Old 04-17-2016, 08:32 PM   #45
drftx
drftx's Avatar
Trader Rating: (42)
Kinda sorta hah thanks!
Old 04-17-2016, 08:33 PM   #46
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Nice key ring mod
Old 04-17-2016, 09:28 PM   #47
s13rhdhatch
s13rhdhatch is an unknown quantity at this point
What kind of mirrors did you buy and where at?
s13rhdhatch is offline   Reply With Quote
Old 05-09-2016, 07:36 PM   #48
drftx
drftx's Avatar
Trader Rating: (42)
Put my aero on!
and then some lady hit me
Fixed!!
Car wouldn't start and found this on the intercooler so I picked up a Greddy for a good price
Old 05-19-2016, 10:03 PM   #49
drftx
drftx's Avatar
Trader Rating: (42)
Small update
Did this little mod will change the hose later on haha
Went ahead and swapped out the old apexi for a HKS
Took me forever to find these
Thanks to pacific nihon I got all 4 !! Took me a hot minute to find a full set of 18s on YAJ
Also snagged these
Old 05-20-2016, 06:59 AM   #50
Mr. white
Mr. white's Avatar
Mr. white is an unknown quantity at this point
Send a message via AIM to Mr. white
I'm stoked for this. Did you get that hose you are using on the Air filter from Home Depot?
Mr. white is offline   Reply With Quote
Old 05-20-2016, 09:15 AM   #51
drftx
drftx's Avatar
Trader Rating: (42)
Hell yeah!!!
Old 05-24-2016, 09:47 PM   #52
drftx
drftx's Avatar
Trader Rating: (42)
Got everything on!! Well the wheels at least.
Got the rear coils on and added my bumper splitter and rear bumper canards.
Dmax hood came in.
Got these cusco hood pins to be like Koguchi but they didnt work with the hood =/
HOOD ON!
Old 06-19-2016, 09:17 PM   #53
drftx
drftx's Avatar
Trader Rating: (42)
Got these guys from the land of Ebay they were for a 350z but, I made it work.
Found this R33 GTR grill on YAJ needs a little work to make it fit.
Got this thing in as well.
I hand sanded this bitch down...
Also put the rear overs on..
Old 07-19-2016, 09:15 PM   #54
drftx
drftx's Avatar
Trader Rating: (42)
Whoops forgot to update
Paint and such
Masking
Sealer layer
Sterling silver base coat
Candy wine coat
Clear coat
Old 07-19-2016, 09:25 PM   #55
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
Go on......
turboshoebox is offline   Reply With Quote
Old 07-19-2016, 09:38 PM   #56
drftx
drftx's Avatar
Trader Rating: (42)
Originally Posted by turboshoebox View Post
Go on......
Old 07-19-2016, 10:44 PM   #57
BigKriss
BigKriss's Avatar
BigKriss is making a name for him/her selfBigKriss is making a name for him/her self
Damn nice colour bud !! Nice build..
BigKriss is offline   Reply With Quote
Old 07-20-2016, 09:17 AM   #58
tricky_ab
tricky_ab's Avatar
I'm loving this colour choice my man!
Instagram
Old 07-21-2016, 08:38 AM   #59
drftx
drftx's Avatar
Trader Rating: (42)
Thanks man! and the support in IG haha!!! Sucks that pictures don't do the color any justice.
Copped these Origin bumper canards to go along with the other canards.
