![]() Join Date: Jul 2003
tie rods are adjustable to begin with.
if you're talking about a performance one (tein, even though it's not really a performance end, just s14 oem basically) then no. most tie rods ends require an aftermarket inner tie rod. |
![]() Join Date: May 2002
yep
i have smoe SPLParts.com tie rod ends coming this week or early next should be here good for lowered cars adj away that nasty bumpsteer, its not so fun. right now i hvae tien rods (inner and outer) works but with the car lowered its not fun sometmes on freeways and espeically in bad weather on the road |
depends
stock inners like s14 would be a worthy upgrade over s13 now rmemeber depends on end too compare kazama and nams tell me which is beefier by looks: NAMS i couldnt say which is REALLY beter but the NAMS definately looks to be. i was going nams but kuah at spl said the spl ones have more adjustment [then nams/kazama] so thats why i went with those..and cheaper. car is pretty low.. i havent looked at the spl ones, im sure they are closer to nams, i talked w/ kuah about nams vs kazama sometime back waybefore his version came out. the weakest part of the tie rod/end setup might be the threaded part, a beefy rod that goes into a small thread part is useless. beefiness all across is key and z32 fits s13/s14 just hve to use both inner and outer kazama: ![]() NAMS: SPLparts.com Last edited by Dousan_PG; 04-21-2005 at 12:17 AM.. |
![]() Join Date: Dec 2002
see i always thought that nam's would do better bumpsteer adjustment due to the angle of the end of the tie rod, that PLUS the heigh adjustability with spacers. oh well i feel like a poser anyways now, i went with cheesesauce kazamas.
www.stewartleask.com |
the spl requires the z32 inners right? That looks like a pretty good upgrade, but you can also use s14 inners and S14 outters on a S13? No mods? If its that much of a difference i might go for some s14 inners on a parted out s14 with some aftermarket outters. Or if i find some z32 for a good price ill go with the spl maybe.
#10 | |
protip: NAMS and Ikeya formula are by no means identical, but look very similar in design (angled end etc.). NAMS are ~$230 retail here, vs over 300 for Ikeya. |
#11 | |
![]() I went with cheesesauce kts.
WORD
CHEESESAUCE, RED, BLUE, SUPER CHEESESAUCE POWERS COMBINE INTO JDM MULTILINK! haha damnit i still want your flcas :whackit:!!!
