SOLD**
the hicas subframe with sensor is GONEGONEGONE. busted axle fogs bumper support Everything is best offer. call or txt me for what you want 562 754 2024. names Dom. here we go.... rear driverside s13 -ruca 5$ -lca 5$ -knuckle 5$ -rotor 5$ -hub 5$ -6 bolt axle 10$ ![]() ![]() ![]() ask me if you want to buy anything off this subframe basically ![]() next... hicas rear swaybar with bushings (will fit non hicas models) -super thick next to OE -good upgrade 60$ ![]() next... passenger side 6 bolt axle that needs a new boot 1$ ![]() next... rear hicas rack w/sensor and hard lines 25$ ![]() ![]() next... s13 NON ABS e-brake cables 15$ ![]() next... s13 rear bumper support 25$ ![]() next... universal H3 fogs with bulbs..these are perfect fit for chuki bumper people...heres how mine looked..will include your choice of switch 20$ ![]() ![]() ![]() next front and rear strut bars for s13 80$ for both ![]() ![]() next chuki bumper brackets 5$ ![]() next... sohc valve cover 5$ ![]() next rear megan street coilovers for s13 i have 1 driverside -1 passenger side...is bent to shitt ![]() ![]() Last edited by S14Cuhh; 04-16-2009 at 06:17 PM.. |
how much shipped for the broken bent megan coilover to 02459? If your willing to part out that broken coilover, I only need the collor where the spring sits. How much shipped for that? btw your pm box is full.
#9 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
How much for the HICAS sway bar shipped to 17562?
#11 | |
I should have some of those camber bolts laying around for free if you like.
KEEPIN IT REAL!
#18 | |
![]() Join Date: Feb 2003
Trader Rating: (289)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 289 reviews
just wanted to give you props on that coilover.
loooks sweet you should make it into a peice of art.
![]() Quote:
#19 | |
![]() Join Date: Jul 2008
Trader Rating: (26)
![]() ![]() Feedback Score: 26 reviews
yeah, it goes with the wheel.
