So i have another rb25 with cut out problems. ive tried different ecu and mafs that work, new ignitor chip, a few different plug gaps currently at .8, insulated coilpacks, timing 15btdc, still had the problem so did the gm ls coil pack swap and started it up and just tested it. well runs the exact same! tested fuel pressure its 36psi and 45psi with vacuum line off with a walbro 255.
So exactly how the car acts... sometimes drives and pulls good no problem sometimes hesitates really hard and cuts out and loses all power and i coast till all of a sudden like 2k rpm drop later it kicks back in, all other electrical is all on just seems like lost all spark or fuel. i dont have my afr gauge hooked up yet to see air ratios(i have innovate lm1 to log but need to weld in a bung for it on my exhaust) anyone experiance any thing like this before ill try anything i have a competition in 2 weeks |
it seems to be a voltage issue on one or more circuits
i would rewire ur f/p and maybe ur coils too also if u check it while car is sitting and running u may not see it my f/p circuit did this only under load...
シチサn w/ka20det:in progressシチサnw/sr20det:stolen |
![]() Join Date: Jul 2005
You are hitting a MAF cut. Sometimes you get a "laurel" RB25, which is an engine from a NON SKYLINE VEHICLE. The maf is smaller, and supports only about 9psi of boost on the OEM engine.
You probably have that maf/ecu, and are trying to run 10+ psi. It will run lean on the OEM injectors and destroy a piston if you keep hitting the maf cut. verify by turning the boost down to 7psi and notice the problem is gone. Solution is larger injectors, stand alone ECU, and a new maf/map sensor to match. |
#10 | |
put a multi meter on the maf voltage wire and verify the voltage does not go over 4.5V at wide open throttle. If it gets anywhere near 5V your problem is the MAF cut in the ECU. If you are losing fuel (fuel cut, brickwall feeling like the engine is shutting off for a moment) and the MAF is not being maxed, you have an electrical issue somewhere, or a bad computer. |
#12 | |
boost leaks, also, read this:
Rich & Retard - Skylines Australia |
just hooked up afr and its weird. im running 10.3 at warmed up idle and 14s when i hold it at 3k rpm put on a nismo adjustable fpr and set it to 14.7 at idle and it started to idle a lot smoother then when i turned the fans on it it leaned out to 17 and died within a second of the fans being on, then it would start untill i set that fpr back to stock.
so what could cause rich idle and lean under throttle? im gunna pressure test it for boost leak but at idle it shouldnt be rich with a vacuum leak |
checked for vacuum leaks best i can couldnt find any and it has 14(negative psi? whatever vacuum is measured in) but found something weird, when the tps is unplugged from sensor top plug it doesnt effect anything but if i unplug the lower tps plug it dies right away
Man this is amazing i have the same issue. Last time it was bad tps or q45 throttle body, swapped both and was good to go. Now i changed my intake mani gasket and same problem except that i changed it again because i thought it was leaking due to stripped bolts. I also have ls2 coils but that was all fine until this mani gasket change situation. Hope someone can shine in on this and ive had boost leaks before it just doesnt seem like one. Its like its dropping a cylinder.
| 240sx, cuts out, hesitation, problem, rb25det |
