Cut Plug
I have a kouki s14 and bought some oem-style turn signals to install. Problem is the previous owner installed Autech blinkers which don't use the side marker lights. Drivers side marker light plug is just hanging out, no problems. Passenger side plug for whatever reason has been cut off.
Are there other Nissan's that share the same plug? How can I fix this? Thank you all in advance. |
| cut, lights, marker, plug, wire |
