![]() Join Date: Oct 2013
Gauging interest: Aluminum Brake Resivoirs to combat melting.
Starting to gauge interest in maybe getting some aluminum brake reservoirs made. I messaged a company about making some as they currently make some for another platform. They asked if I could maybe get 10-15 people, the ROUGH cost per unit would be $200 to start. I understand many people just run heat shields, and are fine with that. This is just another alternative.
Im also unsure whether s-chassis and z chassis reservoirs are the same, but this would be for Z resi's to start. Last edited by tuzzio; 01-04-2017 at 08:59 AM.. |
Will this lead to greater heat transfer to brake fluid and those more prone to boiling?
MRP Manufacturing |
Can I just ask a quick question, would it be difficult to remote mount the reservoir like every single motorcycle or hot rod?
Band aid for a bullet hole
I looked into to this a while ago, seems like good idea
MRP Manufacturing |
This will be a waste of money and time
Look into making a relocating kit like the comments mention that sounds like a better idea to me, only issue I see with that is it would have to obviously be at the same height or higher |
![]() Join Date: Mar 2008
This wouldn't be very hard to do. There are already billet adapters that snap right into the stock rubber seals where hose barbs can be fitted. Not sure how much of a market there will be for these as only a handful of people with giant top mount turbos that are absurdly close to the brake master will need them. Also, most of these hot rodders have remote reservoirs because of space constraints, not heat. If your reservoir is melting, chances are your master is super hot as well.
![]() Join Date: Dec 2006
#17 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
If heat is your concern a metal reservoir that will transfer more heat to the brake fluid is straight backwards. You might prevent a fire, which honestly I've never heard of, but you also might lose you brakes mid-run. To solve the problem you need to control the heat that is getting to the reservoir in the first place. Sorry guy, I don't see a point... |
