ASD Motorsports Intro and Introductory Sale
ASD Motorsports is now a vendor on Zilvia.net! Some of you may know us from the Formula D Falken Tire 350Z, Saturn Sky and Ford Mustangs for Vaughn Gittin Jr and Justin Pawlak that we built and engineer each year. Two years ago we decided to use some of the tools and resources available to us for our race team to manufacture and sell high quality, low cost parts with the grassroots driver in mind. We began with hydraulic e-brake kits and have now expanded into full brake kits for the S13 and 350z, as well as rear subframe bushings for the 350Z. We are currently developing more parts for the S13/S14 and will be releasing more parts for the 350Z. We apply the knowledge and R&D gained from our race program to the products we sell. You can PM or call us at 704-509-4660 M-F 9-5 (EST) for any questions regarding our products or items we sell. Check out our webstore at www.asdmotorsports.com Here are some of the Products we make: ASD Motorsports e-brake kits consists of the following: CNC machined 6061 aluminum handle Wilwood Master Cylinder (pass through or reservoir) Black powder coating on base and master cylinder 6061 red anodized FK Bearing heim joint Aircraft grade hardware ASD Pull up E-brake: ASD 16" Pull Back ASD 10" Pull Back ASD S13 4 Piston Pass Through E-Brake Kit Includes: S13 pull-up e-brake handle w/master cylinder (2) Wilwood 4 piston calipers (2) ASD Caliper Mount Brackets (2) Brembo OEM Z32 rotors Wilwood BP20 pads Complete stainless steel brake line kit Complete hardware kit for bolt in installation ASD 350z Rear Subframe bushings Last edited by ASD Motorsports; 10-10-2011 at 07:42 AM.. |
![]() Join Date: Apr 2009
Trader Rating: (25)
![]() Feedback Score: 25 reviews
^ simple click
ASD S13 4 Piston Rear Brake Upgrade Kit |
![]() Join Date: Jul 2008
Guest
Posts: n/a
BUMP
ASD is a great shop doing great things for the drift industry! GOODLUCK to Tyler clayton and other upcoming ASD Mob members! |
