11-01-2012, 02:48 PM | #1 |
Ka24e won't srart.
I blew up my ka-e, and since i had never done a swap before i decided to go with another KA-e. i saw the engine run before it was pulled from the donor car, so i know it runs.
While doing the swap i deleted all my emissions stuff. I went to start the car and it will tun over but wont start. I have spark, and i have fuel i think. Checked timing, it was good. idk what else it could be. a bad ground? there are 2 plugs on the passenger side of the motor that i cant figure out where they go, But all the essentials are hooked up. What should i check next? |
11-02-2012, 11:19 AM | #2 |
Trader Rating: (50)
Feedback Score: 50 reviews
pictures of plugs would be nice. also check to see if plugs are fouled/flooded=no spark or bad spark. also check you getting gas, you know all the basics first.
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
11-02-2012, 11:36 AM | #3 |
I replaced the plugs with the engine, they look fine but i will post pics tomorrow. I'm getting gas, at least to the fuel rail. I had 2 sets of injectors so i swapped them for the ones i know were working. I've been troubleshooting for days.
11-02-2012, 12:23 PM | #4 |
Check your white dash plug. There is a orange ign wire that gets 12v when cranking, it fires the injectors in a certain order, if that isn't gettin power then it will not start by cranking. Or u can spray carb cleaner in the tb, if it starts and runs fine that will also let u know its the orange ign wire.
