Help Needed. Smog Test in Orange County
Got a Prelim Smog test done on my s14 for California.
I am from Washington, Now in Aliso Viejo. The only Engine Mods are. Injen Intake Tanabe CarExhaust My readings are at "Idle" are. Gas HC......PPM: 1085 CO........%: 3.24 CO2......%: 9.6 O2........%: 2.6 NO(X)...PPM: 224 P.E.F...: 0.474 What should i do to fix it? PM me or reply to the Thread. Thank you!!!! |
You should move away from Cali! lol. On another note like the previous person said what gasses failed and what are the max allowed in the smog test? I want to say its the exhaust. My brother had to swap a stock exhaust on his car for it to pass smog, then once he passed he swapped his exhaust back on. I honestly do not know how you guys do it out there with how strict Cali is...
![]() Join Date: Sep 2003
He failed on HydroCarbons. The engine is running very rich and not efficient at all (CO2 is WAY down, should be around 12%-higher for that engine). I'd start looking for a lazy O2 sensor, or a lean misfire (making the engine not burn the raw fuel, IE hydrocarbons). You'll need a scope (optimally) to check the O2 sensor for being stuck on the rich side. If you're not familiar with diagnosing emissions related components, take it to a shop who knows what they're doing. Emissions can be a PITA if you're unsure, and can be a lot of wasted money at the 'throw this part in' mentality.
In search of a Zenki S14 right side (passenger) fender and straight hood that are rust free. |
| orange county, s14, smog, test |
