09-17-2009, 09:16 AM | #1 |
S13 wheel bearing pressed into s14 hub?
Is it true that if you press a s13 wheel bearing into and s14 hub you dont have to run the s14 knuckles,LCA and all that other BS?
yes ive searched and saw only 1 post regarding it and that was it. just want to be 100% sure. |
09-17-2009, 10:05 AM | #2 | |
Buy the aftermarket hubs and press in new S13 bearings, or buy OE S14 hubs and use matching spindles and balljoints (or the entire LCA for added camber).
09-17-2009, 10:35 AM | #4 |
s13 and s14 spindles have a slightly different taper to them which makes them non-interchangeable. It might look like it fits but it does not and would not be safe. Pretty common knowledge. Like the posters said above...use s13 5 lug conversion hubs or use s14 hubs with s14 spindle and flca. Rear hubs are exactly the same in both cars.
-Retired |
09-17-2009, 10:50 AM | #5 | |
