![]() Join Date: Dec 2001
Stock out put is 10 psi and the motor makes 215 HP with 195 TQ
All of the RB motors were aluminum block and heads IIRC. IC is a small ish side mount like most other stock Nissan IC's The turbo looks like a t3 but the casting on the compressor housing doesn't say. I have read that it is a t3. The Turboon the rb20det is good up to 14.7 PSI from what I have read. That should be a start. -Matt ![]() |
Married to the Mob
Thanks a lot, Matt! <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
I always kind of thought the motor was Iron block, Aluminum head, but I guess not... Intercooler is two-core, 24X12X6, if I recall correctly. Ball-bearing Turbos available? $$$? |
Yes the T3 on the RB20 is a BB from what I have read. It is also a common upgrade for CA and SR turbo's so in theory after market turbos for the SR and CA would also work for the RB20.
![]() Join Date: Jul 2001
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from uuninja on 4:17 pm on Jan. 25, 2002
I could be wrong. I will have to look it up. </td></tr></table><span id='postcolor'> i think west just told u, here is u need to see it. www.freshalloy.com/cars/nissan/nissan_engines.html |
Married to the Mob
Hey, Halo, nice to see you man.
Matt, thanks for the info again. I was also wondering whether SR turbo upgrades would apply to the RB series. I'm seriously thinking of getting this motor for my next S13, but I don't want to get it without the US aftermarket support, and I'm just gathering information now. Thanks, everyone, and thanks in advance for whatever I may get again. <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> |
Autox Technician
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from uuninja on 2:54 pm on Jan. 25, 2002
Yes the T3 on the RB20 is a BB from what I have read. It is also a common upgrade for CA and SR turbo's so in theory after market turbos for the SR and CA would also work for the RB20. </td></tr></table><span id='postcolor'> unless they're also swapping manifolds also...... I was under the assumption T3 and T25 flanges were different... |
