Old 03-11-2009, 04:20 PM   #1
Driven08
Trader Rating: (354)
Driven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfection
Feedback Score: 354 reviews
Unhappy weird Power Steering Problem
So when the car is cold the steering is a little hard but when I drive for a little it turns well up until you try to get it to full lock.
Turning more than 1 whole rotation seems as if the power steering isn't there and it also has kinks in it(goes soft then hard and soft and hard)
I have bled the system like 3 times and tried 2 different power steering pumps and it still the same problem.The rack doesn't seem to be leaking though either but I'm just going to replace it.
Suggestions?
Driven08 is offline   Reply With Quote
Old 03-11-2009, 04:28 PM   #2
DRIFTING_SIL_EIGHTY
DRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to beholdDRIFTING_SIL_EIGHTY is a splendid one to behold
What fluid are you using ?
DRIFTING_SIL_EIGHTY is offline   Reply With Quote
Old 03-11-2009, 04:34 PM   #3
Driven08
ATF Fluid...........
Old 03-17-2009, 09:44 PM   #4
Driven08
Ok changed the steering rack and pinion and it still gets hard when your start to go towards full lock. As if I only have partial power steering
