![]() Join Date: Dec 2013
Where to install oil pressure sensor
Hi everyone I am in the process of installing innovate oil pressure gauge and im in bit of a confusion. Its built sr20 I have I have ebay remote oil filter housing with plate. The innovate sensor only fits the housing which reads only pressure before the filter. So I just got a tomei oil block hoping it would fit the sensor but it doesn't. Sensor is 1/8-27npt tomei block is for factory sensor 1/8-28pt. So before i hack up my tomei and retread it should I leave the sensor in the remote housing. The only reason I'm asking car is not running yet so just cranking it slowly builds oil pressure to 45-48psi seems bit higher just cranking. Any help would be appreciated. Hoping to crank the car this month been down for almost 2 years
I really dont have a reply, mainly a question regarding this topic. I am currently putting new gauges on my 1992 180sx (oil temp, oil pressure, water temp and boost). My question would be, if i use the factory sensor location for the aftermarket one, would it throw a dash light? Also, where would I be able to put oil temp sensor?
![]() Join Date: Oct 2013
No dash lights wouldd come on. It's 1/8bspt so a defi sensor would work. Temp sensor would go into the oilpan. You need an aftermarket pan though.
Need aftermarket parts? PM or DM me competitive pricing! [email protected] |
So you would need a 1/8 bspt adapter to 1/8 npt to make it work.
