#31 | |
#33 |
I finally shelled out for some bigger cams and valve springs I picked them up in a kit for a decent price. Andrew came around and I helped him with the install. We had to rig up the air compressor to hold the valves up while we had the retainers out. Worked a treat though. I wish I had of installed the cam gear aswell though because the timing on the greddy cams seems to be slightly out and cost me more bottom end power than they really should have.
I also got my hands on some corner weight scales and learned how to use them. I could feel the difference afterwards as well the car felt much better with just the driver in it. Bought some new dunlop direzzas which I hated. Would never buy these again. =/ The biggest thing was getting some avs track wheels doing a dogey spray can job on them and fitting up a set of brand new 235/45/17 RE55S tyres. These were unreal to drive on compared to anything else I'd driven on. The colour was pretty damn bright and paintjob shitty. There was an equal amount of lovers and haters :P Random skidpan image. I cant really remember where this slots in so here it stays :P The C's short shifter was sold and replaced with a standard Item. It was much nicer to shift with on the track with the standard Item even with the throw being much larger the other was just too short. (imho) |
#34 |
Keep it up man!, i just got doing the same thing to mine, you changing the subframe bushings? they make a big difference, go with part shop max solid , spl solids or energy suspension polyurethane! Good work!
#35 |
New rims arrived courtesy of Jesse Streeter. Works XT7's 17x9+17 and 17x9+28 filled the guards nicely. Quiet aggressive on the front though. I also bought a dry cell battery and relocated it to the boot for better weight distribution as well as clearing up some space in the engine bay.
Straight to the tyre shop Bye bye to the p1's agressive by my standards anways Jaycar drycell weeeeeeee Love the colour of them =D weeeeee, again. Thanks Kevin for this shot at an NSCC dynoday in 2010 thats NFI's S15 before the widebody in the background (SXDS15) and Philb's R34 |
#37 |
The car was becoming more and more track orientated so I decided to strip out the interior and sound deadening as the start of a reasonably comprehensive weight loss scheme. =)
After pulling out the seat I had to laugh at the 3x stereo cables installed in the car. It looked like it'd been done afew times and knowone had ever bothered to pull out the old wiring they'd just started again. There were some more again under the carpet. Plenty of dry ice works waaaaaaay better than using it sparingly. It came up quite well after some solvent and elbow grease. It didnt take long to get used to the extra noise. The aircon system was also pulled out. Saving me approx 20kg and creating much better airflow to the radiator. The end result of these items netted me this total weight without much fuel in the car. It was a start but still needs to loose alot more weight! 1148 kilograms = 2 530.90677 pounds btw =) |
#38 |
Before the upcoming NSCC day I ditched the old rotors which came with the brakes and fitted some new stoptech slotted two piece curved vein fronts and dba4000 slotted rears. The car also got treated to a reconditioning of the steering rack (it had developed some play) and some new upgraded tein rods/rod ends. I also shelled out for a new set of the whiteline ball joints. These worked much better and are sealed OEM style so should last alot longer too. I also ordered some new track rims while I was at it.
#39 |
wow what a classy build. im jealous that you are able to pour so many good parts into your car, not to mention that toolbox! i like the attention to suspension work. definitely a build im going to keep my eye on
#40 | |
Plenty of power coming soon though cause thats always fun too! =D |
#43 |
^ Cool story, I don't think he gives two shits. Do you do anything else besides thread shitting? Even that wheel-chair dudes cancer thread was fair game for you.
Anyway this build is kinda cool. Can't stand those taillights though, needs moar Kouki. |
#45 | |
#46 |
Devastated!
![]() Have you considered not reading it if you dont like it bud? Just a thought. |
#47 |
New new track rims I'd bought finally arrived. 17x9+22 RPF01's at only 7.2kg per rim they're a very light and well priced option. I fitted up the RE55's for the upcoming track day. I also got my rocker cover powder coated. I'd actually bought another one and got it done so I could just swap it over and not have to leave the car with nothing on it for a week. It came out really nicely I'd actually not seen any other cars with this at the time. There are quiet afew SR20 covers I've seen around with this now. =)
I also ordered an S15 OEM oil cap. These are lighter than all the other aftermarket ones and dont tighten up when the rocker cover gets hot or cold like I've had with the stock S13 oil cap and some of the aftermarket ones. Ended up having to run almost 3 degrees neg in the rear not to scrub. Used some red nissan gasket goo and fitted a new rocker cover gasket before we put it on. The writing had the powder coating shaved off leaving the fresh alloy. Makes it look brand new imo. Pity about the rest of the engine bay :P I bought new washers for the rocker cover aswell. These ended up being some stupidly expensive price well over $100 from nissan australia. I wouldn't have ordered them had I realised. But they did look nice anyhow. Purchased a new Cusco strut brace to replace the old one which was looking rather dated and cruddy. Also the older bar was just one round section between the towers. This flat tube in theory should provide slightly more rigidity. Probably never tell the difference though. =) |
#48 |
World time attack 2010 came around I had my car in the NSCC club display not that I really though it was show car worthy but we got a good club deal and it was a nice close place to park. A car that really changed my perception of what a 180SX could and should be was Wanyes 180. This thing had some serious styling and is hell fast. I was and still are blown away by the attention to detail on both this and later his brothers car, serious dedication to finish I've not seen matched on any other cars in the JDM scene here.
Had had the NSCC day the weekend before. This was the first superlap under the WTAC banner with all the international cars. Was an awesome event! I cant wait for this years!! A short clip I took of Wanyes car at WTAC2010. Clean on a whole new level. |
#49 |
Hmmm whats with you youtube tags comes up with all the embed code in the post and then doesn't actually load it?? I had a look in the faq for youtube stuff and couldnt see anything. Hmmm if someone knows what I'm doing wrong can you let me know please? I've got some more youtube vids coming.
#50 |
I kept having issues with the gauges I'd bought because in the daytime you could hardly see them due to reflection. The oil pressure gauge being near useless cause you couldn't look at it while driving. So I shelled out for a defi link unit and 60mm boost gauge. This let me set parameters which if anything goes outside of it sets an alarm going. Also you can record several minutes of replay and record your peak values. The alarm and peak values are very handy. Especially when setting up your boost controller or flat out on the track. You can concentrate on driving and know you dont have to check any temps unless it screams at you.
The sensor kits I got were oil temp, speed, revs, oil pressure and water temp. Got a new carbon stereo surround. Highly doubtful its any lighter than the standard Item but it looks way cooler =) I also imported a smart camber gauge to help us do our own alignments on the run. |
#51 |
This is some in car of the next track day I made it too. There was so much more left in the car and I was driving reasonably conservatively due to brake locking issues and having tried too hard in the morning. The next session pissed down rain which was fun in itself but not helping me lower my pb at all :P Quickest lap in here shows as 109.2 the official timing had it as 109.16. I haven't had a chance in my car to go back to wakefield since.
#56 |
Here was the last trackday I did in the car before it was pulled off the road. The bottom end finally gave up the ghost on the way home from this trackday after 170,000km and the last 40odd thousand of it making 200ish rwkw
This was my first and so far only time driving eastern creek. Awesome track really forces you to respect turn one or tears are inevitable :P I cant wait to drive it again with some proper aero. ![]() |
#57 |
So I thought I'd post up some pics of cars which have been a big influence on my ideas and slightly pimp the other two SXD cars both which fall into that category anyhow. =) We'll get around to doing a build thread on nfi's car soon too (SXDS15) when we get time. There is alot of work going down on his car in preparation for our WTAC2012 entry and prior testing. The SXDS14A Build thread can be found here if any of you are interested. =)
#58 |
![]() Join Date: Mar 2011
Wow!
Now I can unsubscribe from ns.com, lol. Love the build.
www.motoredge.wordpress.com |
#59 |
![]() Join Date: Sep 2004
cool build thread.
this guys build thread is also awesome I remember reading it plenty of times on the nissansilvia.com website.
Wayne |
