06-27-2011, 06:01 AM | #31 | |
KAe's are tough bastards, my engine went about 20 miles before the meet, and its roughly an 80 mile trip i drove her the 20 to the meet on 3 cylinders and then the remaining 80 miles home and she still would hit 3-5psi boost when i needed it. I love this car it refuses to die i have 2 engines for it. the one thats in the car now with a bad cyl3 and a spare block i just bought. i am doing an OE rebuild on the spare block so i can get the car running again. then i am doing a fully built block with the motor thats blown. depending on the condition of the cylinder walls i will bore it out as needed otherwise stock bore is more then enough. I hope to have the fully built motor done by xmas plan is to run 20+ psi with it tuned properly
KAe-T goal 400whp with A/C - Hatch VH45 track duty - Titan VK56 tow rig |
06-29-2011, 06:08 AM | #34 | |
at that time i pulled motor, switched to a rebuilt P&P head i had for 2 years in storage, installed stg 3 clutch, RX7 460 injectors and replaced the shitty WG with an emusa WG, at that time i ran a @7psi tial spring and ran fantastic. then after a long trip the WG bolts worked there way loose so i figured since i have the WG off let me up the boost, and dropped a tial 4psi spring in. and ran 11psi up until last month when it blew. about 4 months ago i finally got around to installing my n60 maf as well caught quite a few people off guard with it, especially cause i have the WG recirculated, it sounds like a N/A ka till about 2800rpm when it spools.
09-19-2012, 06:43 PM | #44 |
Ka sohc stock block 47k miles ,Gsp t4 .50 trim ,550cc venom injectors ,Z32 maf, 38mm wastegate , hks knockoff bov,Nistune
Dyno'd in at 251whp @ 10 psi with a couple of minor boost leaks . goin back for 12psi when the leaks are fixed Last edited by RedTopKA-T; 09-29-2012 at 03:06 PM.. |
03-30-2013, 04:57 AM | #45 |
anymore info/updates to this thread? i keep coming back interested to see what you guys have done to your single cams lol im thinking about rebuilding my first kae with a blown head gasket but i cant decide what mods to do to my engine also.
04-07-2013, 04:39 AM | #47 |
Quick question. curious as to if its possible to use the SR light weight pulleys on a KA24E with out doing any mods or if its even possible at all. I tried to research. but only came up with one thing and I just want to confirm whether or not its possible.
04-07-2013, 05:58 AM | #48 |
hey redtop that's a sexy single jingle you got there but I hope your not running a stock oil pump with all that line. highly recommend you use a 78 datsun l28 pump bolts right on and will give you 20+ psi additional oil pressure.
and yes you can adapt Sr light weight pulleys to kae a few did it on ka-t.org Sent from my SGH-T999 using Tapatalk 2
Tags |
ka24e |
