![]() Join Date: Apr 2009
need to know the diameter of the rear subframe studs, i have been searching but all i can find is people snapping them off, if anyone can let me know this information it would be greatly appreciated
1990 240sx hatch |
![]() Join Date: Jan 2011
The area where the front of the rear subframe was horribly rotted on my car. I cut the whole are out and replaced it with some rectangle tubing of a similar size. I got about 3 feet of it out of the scrap bin at a local metal supply company and cost me very little. Then I got some 3/4" bolts and put them through the new sub frame mount. After the subframe was raised into place (so I knew the exact location the bolts needed to be) everything was welded solid.
The whole in the solid subframe busings was just a hair over 3/4 so there was very minimal play (less than 1/16 of an inch).With the clamping force of the nut on the solid bushings I have absolutely no worries. |
mine didnt snap off i just need the diameter of the rear studs and i cant find the information on it, unless the info your giving me is that they are 3/4 inch then thank you
