![]() Join Date: Jun 2004
Trader Rating: (73)
Best gaskets for ka-t install
(Also I'm on the hunt for a stock sr20det airbox!)
I'm doing another ka-t in my latest s14. It's the same set up I did a few years ago but with diff parts. Anyway I'd like it to be as low maintenance as possible so I'm looking to buy a set of new gaskets. I'm doing with the powered by max cobra down pipe to eliminate the the elbow to down pipe gasket. So far I've been recommended the mr. Gasket exhaust manifold gasket. Let me know what your recommendations are!
![]() Join Date: Nov 2004
Trader Rating: (53)
wait which gasket. im so confused. for sure cosworth gasket for the head.... the rest i dont know. I am happy with the circuit sports gaskets that I bought though i didn't use it on all parts.
Trader Rating: (73)
Basically anything coming off the the exhaust manifold and beyond.
#6 | |
For the turbo to manifold I use an OEM Nissan gasket which is much thicker and nicer than the ebay and graphite stuff on most websites. I am using a V band to the DP though, but on my old setup I used one from ebay that was single layer SS and held up fine, but again, I always machine everything flat. For headgasket I used a Cometic before, but after 4 years of not using the car it leaked and I went Felpro and zero issues. PS. Always check manifold flanges when you get them for straightness. My DOC manifold had some warpage on the turbo flange when I got it. I also got it relief cut too... why not lol
KA24DE-T whore since 2006.
![]() Join Date: Mar 2008
+1 on the relief cuts, especially for thick cast iron manifolds. My treadstone manifold cracked between runners 3 and 4, which I'm assuming could have been prevented had there been some relief cuts on the flange that bolts up to the head. We'll see how the second manifold holds up..
