Sr Clutch fan stuck
Last night I tired removing my clutch fan to install my efans and wouldn't come off. It's stuck on there pretty good
I know it's 4 bolts on the water pump pulley. Those are off..unless there's more to it..? Last edited by doitsidewayz; 10-10-2012 at 08:56 PM.. |
![]() Join Date: Nov 2008
that's all there is to it. might try some penetrating lubrication and let it sit.. or try tightening them a tad then loosening them.. or try some heat.
Sent from my SCH-R760 using Tapatalk 2
"You always getting emotional after a gunfight" |
i used a flat long blade and wedge it between the pully and the fan all the way around, dont use a screw driver just digs up the pully and damages the back surface of the fan, its rusted in the centre, there is a small hole in the inside stem of the clutch fan that gives direct access to the rusted area, spray some penetrating fluid in there be patient but it will come out dont try too hard to bend anything a little patience and it will wiggle out............mike
Man w/ CTSV & a Car Seat
Just dont hit it too hard. Remember, its attached to the water pump. Last thing you wanna do is whack it so hard that you break the water pump bearings too.
My bad didn't realize you had the nuts off... prybar an
d a little patience. Sent from my SCH-R760 using Tapatalk 2
I had to use a pry bar and hamer it in, I opened a good size gap to be able to pry it out. And bamm! Busted radiator lol
It was a supper tiny hole. Had some radiator sealer and fixed it. For now at least |
