These kits are designed for anyone looking to go Boost by gear, pwm, or add an electronic boost controller to their turbo Setup. These kits will work on any vehicle that has the ability to control pwm through the ecu. Most engine managements system due.
Example, aem, nismotronic, ems, mega squirt, haltech, motec, just to name a few We have multiple kits available for almost any Turbo Setup. 3 Port Boost Controller w/ Single Wastegate 3 Port Boost Controller w/ Dual Wastegate 4 Port Boost Controller w/ Single Wastegate 4 Port Boost Controller w/ Dual Wastegate Additionally, there are options for running this kit from the turbo or your intake manifold. What turbo you have will determine this. The product description will explain. **Please read before ordering** All kits come with Nickel Plated One Touch reusable fittings and Nylon Tubing. These are very high quality products that are designed to last. Nylon (polyamide) tubing is designed to hold up to 80 Bar burst pressure. We also offer our custom Mac modified high temp boost solenoids with the kits if needed. Last edited by JBtuned; 05-25-2014 at 11:03 PM.. |
Please PM us with any questions you may have. or visit us on www.JBtuned.com
| boost by gear, boost controller, ebc, one touch, turbo |
