Old 05-26-2015, 02:00 PM   #1
slidingsideways09
slidingsideways09 is an unknown quantity at this point
s13 91 ka24de not starting Need Help PLease
Ived searched hours and found nothing that could help me out, if someone could find the information I'm looking for could you add the link or you know of write write up please post. Thank you
Okay I have a 91 240sx ka24de all stock, since last week i couldn't get the car to turn over and start. Ive check the battery thinking it was dead, but the auto parts store told me it check out good, then i thought it could be the switch behind the clutch,replaced that and no start. then i found out there is an relay on the passenger side fender, I've also replaced that and still no start or crank over. Then i took an multi meter to the starter and had my friend turn the key to the start position and it gets 12v. so then took my multi meter to the starter relay but that gets nothing, so I'm thinking my ignition switch is bad in the start position, so the next day i went and bought an 15amp starter switch, and hooked it by cutting the wire behind the ignition switch, the wire Ive cut was black/yellow and black/white, connected them to the push switch. Tried to start the car again and still got nothing. Right now I'm completely lost. the car does have an kill switch and a viper alarm with a starter kill. Right now I'm thinking about disconnecting the alarm and see if that helps. Oh p.s did try to push start the car manually and the car still did not start. Could anyone help me out?
slidingsideways09 is offline   Reply With Quote
Old 05-28-2015, 12:33 PM   #2
slidingsideways09
bump! Anyone??
Old 06-19-2015, 06:21 PM   #3
The Saint
The Saint's Avatar
The Saint is an unknown quantity at this point
Gray 75amp fuse.
The Saint is offline   Reply With Quote
Old 06-25-2015, 08:50 AM   #4
caracol
caracol is an unknown quantity at this point
check your ground.
Last edited by caracol; 06-25-2015 at 08:50 AM.. Reason: excess word that i didn't mean to type
caracol is offline   Reply With Quote
