S13 dome light not working **Solved**
Solved. 2 plugs behind the dash weren't plugged in
Bought an s13 and the dome light and clock weren't working. Checked all the fuses and found out the 10a room lamp fuse was blown. Replaced it and the click started working but not the dome light. Replaced the bulb, still nothing. Realized the harness wasn't plugged in. Big smile, thought it would turn on now! Plugged in the harness. Still no light Any help here?
S13 Hatch Drift Build: #/f/showthread.php?t=608621 Last edited by vinnyjdm; 10-16-2015 at 08:49 PM.. |
Any ideas? The glove box light isn't working either if that counts for anything!
S13 Hatch Drift Build: #/f/showthread.php?t=608621 |
![]() Join Date: Feb 2012
Trader Rating: (37)
![]() Feedback Score: 37 reviews
See if the fuse blew again when you plugged in the subharness for the dome light.
Check for continuity at both ends of the subharness. If continuity is there, check for 12v power w/ the subharness plugged in. Check for continuity on the chassis and the ground for subharness. Check the door sensors in both door jams. Make sure they are plugged in, (I would do this first before the aforementioned).
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
#4 | |
i'm going to have to follow the harness from the dome light to find out where it goes. hopefully i'll be able to do that without pulling the dash
Figured it out. 2 of the harnesses behind the dash were unplugged
