![]() Join Date: Dec 2004
Trader Rating: (58)
Hey guys, just have way too many parts laying around that I don't need 3 spares of. Let me know if you're interested in any of the following parts!
Attached a few pics of some of the parts, but lets be honest, we all know what they look like, and my perfect trader rating should speak for the rest. This stuff isn't junk, nor does it need to sell as it's really not in the way. Aftermarket parts/Performance Parts: Stock Wastegate with External Waste gate provision (Tial 38mm and MVS available) 160 dollars (If you give me your stock manifold I'll take 40 dollars off that price) Air Conditioning Conversion kits, for KA compressors on SR20 engines - 70 to 110 dollars depending on engine, and setup Quest Alternator Conversion brackets, allows the use of 115 or 125 alternators on SR20 engine - 55 dollars Tomei Gen 1 Oil Pan: 225 dollars Exterior Parts: S14 Navan Fog Lamps (projector) - 60 bucks Internal Parts: S13 Dipstick Tube with Dipstick - 30 dollars S13 Water Neck outlet with tapped 1/8" NPT port (for a guage) - 20 dollars S13 Redtop Injector Rail (no caps) - 25 bucks SR Coil Packs (3 total) - 20 a piece SR20 Waterpump - 25 dollars (2 of them) SR20 Upper Oil Pan - 45 dollars SR20 DET Pistons (No Rods) - 20 dollars a piston, 75 for all SR20 Rear Main Seal Housing and Seal (2 of them) - 30 dollars SR20 Cam Gears - 30 dollars a set The gears are the same. The CAS drive can be included if needed. Great upgrade for those with S14 engines not wanting to deal with the VTC SR20 Timing Chain - 30 dollars Misc: Engine Removal Hooks (6 sets) - 25 a set Fit great, makes for easy removal of the engine. Suspension: Z32 Rear Aluminum Uprights with ES Poly Bushings Installed: 75 dollars S14 Rear Traction Arms with Poly Bushing Installed, and braced/welded - 25 dollars.
#3 | |
Trader Rating: (58)
Trader Rating: (58)
Cool! If you want to purchase them directly, check out my website CodyAce SR20 Air Conditioning Bracket follow the purchase page for a direct paypal link
| air conditioning, alternator, pistons, uprights |
