| Polls Post All Polls in Here. |
| View Poll Results: So, how much do you know? (installs you have successfully performed) | |||
| 1...I know how to drive 5-speed |
9 | 5.11% |
| 2...can change oil, tires, spark plugs, caps, rotors, have a pretty good understand of how things work |
54 | 30.68% |
| 3...clutches, axles, driveshafts, cams, timing belt/chain, able to work on some internals |
44 | 25.00% |
| 4...engine swaps, headgaskets, figuring out wiring, diagnosing problems, |
41 | 23.30% |
| 5...internal engine building, measuring tolerances, complete understanding of the modern day internal combustion engine (emissions,timing,vacuum,cooling,oil,etc.) |
22 | 12.50% |
| 6...full race fabrication, cages, weird engine swaps, etc. |
6 | 3.41% |
| Voters: 176. You may not vote on this poll | |||
#32 |
![]() Join Date: Sep 2002
im at about a 4.25 right now, but will be graduating to 6 soon (i hope i plan on building a cage and fabbing some cool shiz this winter!!!
) amd then later ill go back and do 5 ![]()
00 impreza 2.5rs sedan...dd 00 impreza 2.5rs coupe....EJ255, goin rwd!! |
#33 |
![]() Join Date: Apr 2003
3.5
could be at 4, but abhore wiring...i hate it....
LP stylez!! bishes Lazy Penguin since teh 04' ![]() Part of the Elite Shasta Speed Stars RIP......05-09-03....*sniff sniff ![]() the beast nears completion..... ![]() YOU LOOK AND U BUY STUFF !!!!! |
#37 |
I was raised by two mechanics, my mom is ASE certified smog tech, and my dad can work on things with carburetors and, build engines all sorts of stuff. He just never got certified, but he can do anything when it comes to engines ( as long as there not fuel injected ) My knowledge is okay I give it about a 4 but I can work on cars, with no problem I started doing it when I was like 5 so I just know how, other than that I think im going to go to UTI and get my ASE master tech. cert. one of these days.
#39 |
![]() Join Date: Sep 2003
<4, by the end of next year i will be a 6.... but what about autobody and paint? those things dont count.. if they do would that bump me up to a 5?
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#41 |
![]() Join Date: Mar 2005
i would say im 2.5ish to 3. ive never done a swap, but i have taken an engine apart and put it back together. im the guy that likes to understand how things work more than getting my hands dirty. i pay to have alot of shit done mostly because i dont trust myself. so yeah, i do much much much more reading about automotive than physical "stuff". werd.
-Dane |
#44 | |
you left out 7: I have a whole lot of posts on internet forums
#45 |
![]() Join Date: Jul 2004
I chose 2, although its probably 3 or 4. I have not been able to see if my efforts at my engine swap and wiring myself have paid off, so I cannot really say I've done those things successfully. Assuming everything worked out good, I'd say between 3 and 4 for myself. I've learned a ton from this website as far as research goes.
#47 |
I'd say a 3.5 really....so I rounded up and chose 4.
2003 Sentra SE-R Spec-V (fully bolted with much more; autoX) 1989 S13 240sx Coupe (RB20DET yet to be installed) |
