![]() Join Date: Aug 2007
Hey everyone. I am in the process of getting everything together to have Brian make me a hybric vc. I have a quick question though. Once the black box is removed from my redtop, can I just connect the line to the fitting on the back of the notch top vc? Or do I have to make a new line? I can't really see where it goes. Any help would be greatly appreciated. Thanks
AFC #1
![]() Join Date: Oct 2003
There are 2 ports on the exhaust side of the S14/5 VC. One in the back for the block and one in the front for the intake. You would hook the line up to the back like you suggested.
![]() Join Date: Oct 2009
Up from the dead.
Im about to be running a Hybrid Valve Cover on my Sr. Are the valve cover gaskets the same between the S13 and S14 Valver covers? (valve cover & coil tube seals?) Also, Ive heard rumors that when switching from the flat S13 valve cover to the S13/S14 Hybrid, the coils need to be switched out for S14 coils. Does anyone know if this is true? or is it not true and I can still use the S13 coil packs. Thanks for the help! |
| hybrid, valve cover |
