Old 07-15-2014, 03:10 AM   #1
l adam l
l adam l's Avatar
l adam l is an unknown quantity at this point
r32 rb26 r33 rb26
How do you tell the r32 rb26 from the r33 rb26 other than taking the engine apart and looking at the crank collar?? Anyway to just look at it and tell?
l adam l is offline   Reply With Quote
Old 07-15-2014, 03:39 AM   #2
Sileighty_85
Sileighty_85's Avatar
power steering pump and wire harness
Turbo part numbers
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-15-2014, 05:10 AM   #3
l adam l
l adam l's Avatar
Are the ecus the same? ...guess this could be searched. Thanks for the reply
Old 07-23-2014, 10:05 AM   #4
rbs14kouki
rbs14kouki's Avatar
If i remember right !! ! R33 and r34 have a connector comming out of the front of injectors harness (that plastic where all the wiring areand its cliped on the balance tube) and it goes in between runner 1 and 2
My r33 engine was like that and my buddy r32 wasnt
AV FABRICATION
Built thread sr20vet s14
#/f/showthread.php?t=535574
Old 07-23-2014, 10:08 AM   #5
rbs14kouki
rbs14kouki's Avatar
You see it here right over the injector#1 ... Its a 8wire conectors
http://3.bp.blogspot.com/-yrjM-ECpu6...0/IMG_2702.jpg
AV FABRICATION
Old 07-31-2014, 12:01 AM   #6
l adam l
l adam l's Avatar
Thanks! I'm going to be ordering one here shortly and don't wanna be dooped. Honestly still debating between a series 2 25 and r33 26...
Old 08-14-2014, 01:23 AM   #7
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
I had a series 2 rb25....still had the short crank snout and ignition coils were a bitch to source. The series 2 also has the ceramic compressor wheel that likes to explode whenever it feels like. Go with the r33 rb26, or a JZ....
'92 HB HX35 rb25 - sold
'89 Coupe GTX35 VVT-I 2JZ - yeah buddy
AS240 is offline   Reply With Quote
Old 08-14-2014, 01:33 AM   #8
l adam l
l adam l's Avatar
yeah, i knew about the crank collar. i have 8500 to spend on it, trying to save more because i'd like to do suspension, rims and tires, and brakes. been debating weather or not to go ahead and order it, and drop it in. then i start thinking about the 25 and having enough for the suspension as well.
Old 08-14-2014, 03:33 AM   #9
Sileighty_85
All RB25 before the R34 NEO engine all have short oil pump drives.
All RB Turbos are Ceramic except Nismo Turbos
But just a FYI, some early model R33 RB26's came with short cranks as well.
後輪駆動車1番
1986 SR86 - 200ish
Old 08-14-2014, 09:40 PM   #10
AS240
AS240's Avatar
Trader Rating: (18)
Yes they all came with ceramic turbine wheels....but the series 2 also had a ceramic compressor wheel. I swapped a S1 turbo onto my S2 for this reason.
Old 08-14-2014, 09:59 PM   #11
l adam l
l adam l's Avatar
But just a FYI, some early model R33 RB26's came with the short cranks as well.
I've heard some of the early neo25s have the short collar as well. didnt know the r33s did. Good to know. Now I have something else to debate...thanks for the info.
