will my car run 14 seconds?
I'm not usually much of a bench racer...but this seemed interesting-my buddy just bought a new scion fr-so (not supercharged). Online specs say it's about a 14.9 second car...also it says the stock 93 240sx is a 16.1 second car. I just rebuilt my motor and haven't installed it yet.
My mods: - Sohc pistons for a little higher compression - 98 model head with 3 angle valve job - Port matched intake with butterflies removed - msd blaster 2 coil - walbro 255 lph fuel pump - 4-2-1 header with 3 inch exhaust - egr block-off plate - electric fans - no a/c - no p/s - removed charcoal canister - adjustable fuel pressure regulator (can someone tell me the ideal setting for it? It was on the car when I bought it) - stage 3 6-puck clutch - 1.2" drop springs - kosei r-seneka wheels with 215s out back - poly mounts Do you guys think that this will get me into maybe the mid 14s? I know gains are a lot harder to get on a N/A motor. Thanks for any input! Kevin |
A lot of it has to do with your driving skills,suspension setup and most importantly what tires you have.but with yours parts list I don't see a massive whp gains to make a massive difference in your 1/4mile to a stock ka24de.
Instagram username:angelmkiv |
![]() Join Date: Jul 2009
![]() ![]() Feedback Score: 13 reviews
Adj fuel pressure reg and high flow fuel pump with stock injectors?
Now that you're a bench racer you can make better guesstimates with this http://robrobinette.com/et.htm |
![]() Join Date: Jan 2007
Ummm... so when did Georgia become part of Florida?
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
-Robert R. |
Doesn't matter. Both cars are slow as hell. Trying to extracting real power from an N/A KA is pretty high on the list of collossal wastes of time.
![]() Join Date: Oct 2005
I say no, you won't be able to win the FRS unless you totally strip out your car. You may stand a chance! Then again paper is one thing and actually racing is a whole other thing. Let the driving do the talking.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
| clutch, fuel pump, ka24de, race, scion |
