![]() Join Date: Oct 2006
Trader Rating: (163)
S13 Center Vent Angled Triple 52mm Gauge Plates
S13 Center Vent Angled Triple 52mm Gauge Plates: $75 shipped
Please inquire if you would like non-angled 52mm or 60mm NOTE: Please allow up to a week for the fabrication. These are made to order!
![]() Rings are 100% flat on the bottom: ![]() Example of modified bracket to fit a specific gauge: ![]() Example of how you could drill and tap the modified brackets and insert threaded rod into it. Then simply use some aluminum or other material to make a "washer" to span the back of the vent opening. Finally some simple wing nuts and you can easily attach it all from the back. This will also help really suck the plate into the opening of the dash. ![]() UPDATE: As I have mentioned in this thread, I can have any combination of gauge placements fabricated. For example: Chase from Chase Bays wanted a plate with one 52mm at the end and that was it. No problem! I can also do triple 60mm non-angled, double 52mm with vent angled or non-angled, any # of 52mm or 60mm from 1-3 or any combination of. Note: these are all special order so allow up to 4 weeks for delivery. Price is the same($75 shipped) for all angled plates and $40 shipped for non-angled. NOTE: 60mm cannot be angled in the standard fashion. All pieces are finished just like everything else: textured and painted with high quality satin black to best match the OEM finish of your S13. Some Examples: Triple 60mm: ![]() Dual 52mm with vent: Dual 52mm angled with vent: ![]() Last edited by Broadfield; 05-15-2012 at 12:08 AM.. |
I do not because there is no demand for them. However, I can have one CNC'd if you would like. It would probably be a month or more though before I put in another order to the metal shop.
I do have a dual 52mm holder, but it has the slots in between for the vent to still function somewhat as a vent. You could still do the angled rings on it if you wanted. Otherwise like I said above, if you want the dual holder without the vent openings, then I would have to special order it the next time I place an order. Thanks, Toby |
I cannot sell the brackets separately as they come with the angled rings. |
![]() Join Date: Apr 2008
Trader Rating: (161)
![]() Feedback Score: 161 reviews
Nice job Toby, glad somebody thought of making this a complete kit! I might have to pick one of these up from you soon! Bump for quality work.
180SXオタクだ! |
![]() Join Date: Jun 2008
not that i need to, but i can vouch for toby's work. it is above and beyond ANYTHING i've ever seen in 7 years of being an automotive enthusiast. i'm debating starting an s13 overhaul/restoration for a dd...if i do i'll be taking one of these.
![]() Join Date: May 2006
Nice, I've been wanting these for a while now. I've purchased from you before, but it's been a while. You do paypal right? Can you send me your paypal info or whichever payment method you'd like?
#16 | ||||
![]() Quote:
Add $10 Quote:
Please enter in the comments box what the payment is for. Thanks guys! |
#22 | |
Thanks, Toby |
#28 |
![]() Join Date: Feb 2011
do you mount\glue the rings on the plate, or do they have to be assembled? because i attempted to do this with the autometer rings after seeing your car in the magazine a few months ago, but i failed at getting them all straight, they were all different angles lol.
#29 | |
that's what im looking for how much is the one with the vents |
| angled gauges, broadfield, s13 center vent gauge |
