![]() Join Date: Jul 2012
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Reverse Lights
i've had several people tell me at red lights that they noticed my reverse lights are on while they're driving behind me. how do i fix this? what should i check?
i have a 1991 240sx coupe thanks |
i looked at it closer last night and i believe the wiring is switched between 4th gear and the reverse position. where can i find the gearbox wiring? I dont have a wiring diagram
![]() Join Date: Aug 2011
there are only 2 sensors : neutral and reverse . And they are just switches. just switch the plugs and you are done (chances are the sensors have been switched as i believe the plugs are not the same)
#11 | |
![]() Join Date: May 2009
There are more then two sensors. If you cant start your car after you swap these sensors around or can only do so in reverse that means that the issue is not in these sensors. You could have a short in the wiring for your reverse lights.
Here is a good pictures with labels. Swap around 1 and 4 and see if that solves your issues. EDIT: I reread your post and noticed they said its at red lights, is it only at reds? If so that for sure isn't those sensors and could be a short. That crappy bulb holder setup has a tendency to melt if you put to high wattage bulbs and all kinds of strange things happen.
Wow, I'm reviving this thread almost 7 years later lol
so I just realized I never fixed my reverse light issue back in 2012 the reverse lights come on when I'm in 4th gear instead of reverse do I just have the sensors plugged in wrong? |
#13 | |
back from the dead, yet again. |
