Turbonetics, Bee*r, pop-ups
Hi, have the below items for sale. Let me know if you have any questions or if you need more pics.
Brand New Turbonetics 60-1 T04E and V-band Exhaust - 600$ shipped It has a 60-1 trim to4e compressor wheel with stage 3 turbine wheel. The exhaust side is a T3 flange with a .63 turbine A/R and a 4 bolt outlet. Never even been mounted and comes with the original tag showing the balancing was completed in spec. You can look up part # - TBN-35125 to see the brand new pricing for the turbo. V-band adapter is not pictured. Bee*R Power Builder 2 step - 200$ shipped Unit is in perfect shape, has some double sided tape on the bottom that can be cleaned up easily. Wire is already cut for 4cyl but can be soldered back if you are using this for something else. Front Auto seat belts Rails and Motor - 50$ per side shipped or let me know if you just need something specific and we can work it out. Climate control unit, has a burnt bulb but otherwise works great - 15$ shipped OEM Coolant reservoir, no holes but wore out on the corner - 10$ Pop up headlights, motor included. Already have a H4 conversion with projectors. Paint is in good shape. 35$ shipped per side or 60$ shipped for both. |
