Okay so a few questions for the ka24de high compression motor build. I have a 0.040 bored motor with oversized e pistons with a shaved head for more high compression i am not sure how much. Anyway, its a scary motor as is believe it or not for a s13 hatch.
Thoughts on putting low boost? Thoughts on sr20det 370cc injectors? Thoughts on hot cam mod? Thoughs on upgraded bigger maf? Thoughts on an ecu tune, boosted or n/a, after injectors, maf and hot cam if it happened? Im just looking for positives and negaitves on them so i can decide yes or no to all. I know high compression is not good with high boost thats why i said low boost like 5lbs max. The injectors i figured less pulse, more gas. With pemium always and a hot cam mod to let more air fuel mixture in making more torque on high compression. Has long tube headers now, and full 3in. Cat back with test pipe. Also has intake bolt ons. Thoughts everyone? |
