#61 |
![]() Join Date: Jun 2010
my set up right now is really challenging to drive. NONpower gearbox steering with high angle knuckles comes out to 7 turns lock to lock. even with a gang of shims in the UCA's to add caster i only got about 8.5* and its just not enough.
the weight distribution is tricky too the ass end is always trying to pass you up even when im not drifting...I.E. scca type events and other time attack driving. and even tho the rear end is super light it still feels really underpowered. runs out of steam mid drift. so all of this = attacking drifts with i high speed shallow line. (which is not gangster in my book) hopefully the s13 front suspension and steering and v8 will fix all these things =] and MAPERFORMANCE i was having a big issue with axle hop in the rear too! i played with the mounting points of all the links, tire sizes, and spring rates and valving. DID NOT FIX ANYTHING! what did fix it was adjusting the pinion angle. i was at 0* then i kicked the the pinion up 1.5* and the problem went away thank god! |
#62 |
so finally!!! today was the day i got to really tear into the truck, keep in mind at the begin inning of the day this was a complete truck and this was all accomplished in about 7 hours.
so i commenced in tearing down the interior, and removing all the KA wiring (notice the new bars for the cage) and the KA I ripped out of it that only have 7000 miles on a rebuild lol what my truck looks like and i got the s13 engine crossmember mocked in place (just tacked, will be fully installed tomorrow) oh and some of the parts from the d21 will live on in this, my newest addition to the family slowly but surely this thing will get completed |
#63 |
ok so this is how i decided to mount the s13 clip
i made a set of frame spacers out of 2x4 120 wall and trimmed, bent, and mocked them up heres what they look like the reason i had to do this is because the s13 clip's mounting holes are a lot wider apart than the stock d21 frame rails. comparison photos heres the spacers mocked up had to drill holes through them to mount the crossmember, here it is bolted up... keep in mind the spacers will be fully welded to the frame... i just don't have good pics of it yet. BTW the s13 steering column bolted right in to the stock mounting behind the dash and lined up perfect with the rack and pinion, ill have pics of that later on |
#65 |
ok so heres how the spacers look welded to the frame
still gonna gusset it more to the frame, the fish plates are 1/4" some full shots with the rack and column in how the column fits through the fire wall and check it out! it bolts/ fits in the stock location, and positioning feels right on the money thats gonna be it for a little while, i need to start building the motor, and bolt a trans up to it before i start cutting the fire wall and making the new trans x-member |
#70 |
got a little bit done this weekend.
got the spacers fully welded in and threw a quick shot of paint on them. ^^^ if those things budge at all I'm going to quit working with metal all together lol got two crossbars welded in for the cage.. just need door bars and shock hoops current state of the truck and it was 1/2 off at the bone yards. got an alternator, power steering pump, oil pick up tube, ignition coil, and a MAF super cheap! found the trans i need up in compton having a friend scoop it up for me =] and i did my taxes and found out I'm getting a ton more than i expected!!!! so I'm getting the trans adapter kit a lot sooner than i thought i would =] |
#73 |
thanks guys... and the trans adapter I'm getting is from quantum auto, 1uzfe-w58 w/ steel flywheel kit. doesn't come with a throw out bearing.
so kit= 900+shipping and throwout bearing= 200+shipping FML =[ |
#74 |
so i got my heads back from the machine shop and oh boy they look good =]
full 3 angle valve job, resurface, and thorough cleaning.... had to replace 4 valves due to rust and age |
#75 |
so i was up in LA today and tried to scoop up as much crap as i could with my limited cash and came back with some good parts that i needed
w58 trans and s14 uprights pretty stoked |
#76 |
mounted the rack and crossmember with the right hardware hopefully for good
stripped out some more wiring and painted the rusty ass metal behind the dash, and mounted the column and heres the little BS bracket i had to make to keep it from shaking cold run wheel fittment teaser shots about how much camber i expect to be running lol |
#77 |
so i got a litle sidetracked today and started on the drop spindles for the datsun 620
d22 drop spindles with d21 wheelends cut out the front crossmember, gonna make a new one with new tc rod brackets. but i was mocking up the stock lca's and tc rods and noticed a little problem... they are way to short!!!!! gonna have to make a new set about 9" longer =0 i need to start puttin some of all this crap back into the truck lol |
#78 |
so check it out i got some of the good stuff done today =]
both heads on full frontal so much shit on the front of this....FYI this was just test fitting of stuff, getting a new water pump and belt tensioner, just wanted to see how it went back together my local machine shop stamps your name into your parts, i dint know they did this but i think its really cool and just incase you forgot what kind of motor this is |
#80 |
this past weekend was the maiden voyage for the beast, and man it surpassed my expectations big time. not a single problem all day.
the truck seemed to be a crowd favorite which was awesome. felt so good to be out finally doing what i love. and the truck just worked flawlessly i had never felt a sense of accomplishment like i did after my first lap. i was at a loss for words and i probably looked like a 10 year old kid on christmas morning. only casualty was a flare popped off, and one of my idler pulleys is going bad i think. and heres a video of the majority of the day, sorry for lack of footage. dead go-pro and friends that cannot operate a camera that isn't on their phone……. |
#86 |
Sweeeeet!!! This thing looks like a mini dually..
The paint im still thinking about it... Kinda like the iDX lol +1 too much work in that truck for a 10 min paint job.
Late Night Crew #1 |
