#2 | |
![]() Join Date: Nov 2010
If you are a real human, try and lay out your post in a question format with some of the steps you hav taken to correct the issue.
![]() Join Date: Jul 2005
I wouldn't worry about it unless it affects the performance / driving characteristic.
A misfire can be related to all sorts of issue, from lean condition, improper gap, wrong plug wires, exhaust gas contamination (hmm. Headers + straight exhaust). I bet there is a 51% chance if you re-installed the OEM exhaust it would stop. |
I been thinking also could it be that also I don't have a heat shield on the headers and the stainless steel headers are getting my wires to hot???
1NE |
