#121 |
For cutting, did you guys cut all the way down to the frame rail and weld your new sheet directly to the rail? I think I saw that on a few builds, but I just wanna confirm. I have some rust a few inches above my frame rail so will be so this will be a dual-purpose tubbing.
#123 |
![]() Join Date: Mar 2007
On ours, we cut down to the pinch weld where the inner and outer sections meet. We then used a hole punch every inch or so on the tub to allow for strength when welding. Overlap the two sections and fill. You basically fill in each hole with weld, creating a stronger bond than a seam/stitch style weld.
#124 |
![]() Join Date: Dec 2003
I would STRONGLY suggest leaving the seam down there in tack. The only reason that "rail" has any strength is due to the seam. Get you a spot weld drill bit and remove the panel as one piece.
mine was already pretty hacked up so I had to separate it into two pieces but you get the idea. I'm still planning to remove more material from the shock tower but that can wait until I'm welding in the tubs.
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson Last edited by s14unimog; 06-26-2011 at 09:48 PM.. |
#125 | ||
And I have a few spot weld drill bits lying around..... Thanks for the help guys ![]() |
#129 |
^^ Fantastic job! Exactly what I'm after. I'll post my results in the next day or so. Here's a quick shot of the factory fenders just "un-installed"
#132 | |
can i just ask what thickness metal i should be using for this (i have trailor fenders on the way already) also where are people mounting there PAS resevoir's? |
#133 | |
#134 | ||
The fender I used. 16-Gauge Steel, Single-Axle Trailer Fender, 10-3/4" Wide - 14" to 15" Tires Redline Trailer Fenders F1075X32-1R
S12 || KN13 || S13 || B16 |
#135 | |
copied from my build thread
where im at Quote:
#138 | |
what me and a friend got done today:
#139 |
![]() Join Date: Dec 2002
not finished yet but an idea
www.stewartleask.com |
#141 |
Good job everyone looks good, I need to get around to doing this on my s14 haha
http://st4tus.blogspot.com/ http://waytooclasssy.tumblr.com/ Looking for an s14 BN kit prefer real but still will buy if its not also looking for 18" 19" advan model 5, ssr agle, minevras, kranze lxz |
#142 |
finally finished...
all done with just 1 of these... Shipshape Steel Tandem Fender with Teardrop 72in. Long | Trailer Fenders | Northern Tool + Equipment and 4 1'x2' sheets of 22 gauge from home depot. if your car is oem core support and has most of the sheet metal up front you can probably get by with just 2 sheets
#143 | |
#147 |
Finally finished mine! Gotta get ready to paint now...
#148 |
![]() Join Date: Jun 2011
i wish i used trailer fenders, i made mine by hand using 20g scrap metal that i had laying around.
I made mine because of the hack job done to the car for IC piping access, more clearance, it was easier to fit my s14 rad support, and it looks way cooler. I rivited them first because i was too impatient to wait for my welder to show up. but then i (practiced) welded and seam sealed with Dow 418 Primerless Urethane. |
#150 |
Not my choice of design but it seems pretty clear to me why...
