![]() Join Date: Feb 2004
![]() ![]() ![]() Feedback Score: 6 reviews
1995 Nissan 240SX S14 Kouki SR20DET Slicktop
I am ready to part ways with my 1995 Nissan 240SX, which has passed Colorado emissions testing and has a clean title. It is ready to take to the track as-is for high performance driving events. Optionally have a roll cage fitted for wheel-to-wheel racing, or re-install interior and HVAC for a daily driver. Has been owned (since 2003) and built by a mechanical engineer and Nissan enthusiast. Only 111,500 miles on the chassis, which is quite low for a 21 year old vehicle.
This S14 starting life as a manual transmission, base model Zenki slicktop, without sunroof, which makes it essentially the lightest and stiffest S14 chassis available. After the front driver's side fender was hit while the vehicle was parked, I swapped the fenders, hood, lighting, and headlight supports over to the OEM JDM Kouki (1997-1998 style) parts. After daily driving it through 2007, I started building it into the track-ready car it is today. I removed the KA24DE engine and fitted the period-correct S14 SR20DET engine and transmission. I upgraded the fuel pump with an OEM Z32 (300ZX twin-turbo) part, not a typical Walbro part. Has only been run at 12psi (fitted with an HKS wastegate actuator) with is well within the stock turbo limit. The engine is running on the OEM ECU, which is to say that it runs perfectly at any altitude. I eliminated all unnecessary interior components and sound-deadening material to minimize weight. HVAC and power steering systems have been deleted. Stance Al+Pro coilovers allow height and dampening adjustment (as well as spring rates by swapping springs). Car has been corner weighted with driver, with a total wet vehicle weight of 2,375lb and 52.4%/47.6% front/rear weight distribution. Wheels and tires have been sized to maximize grip while maintaining OEM steel fenders. They are... 5Zigen FN01R-C 17x8 +25 w/ Dunlop Direzza Z1 Star Spec 235/40R17 (front) 5Zigen FN01R-C 17x9 +35 w/ Dunlop Direzza Z1 Star Spec 255/40R17 (rear) This car has been a blast to build and drive, but I simply don't have the time to enjoy it anymore. I'd love to see it go to another enthusiast who will take good care of it, as I have. I have a complete parts list on Google docs and a folder full of receipts which will be given to the new owner. Drivetrain S14 SR20DET and 5-speed manual transmission Nismo Engine/Transmission Mounts Greddy Aluminum High-Capacity Oil Pan Xcessive Front Steel Skidplate HKS Manual Wastegate Actuator Z32 Twin Turbo OEM Fuel Pump Intake Blitz SUS Power Intake GReddy Hotpipe GReddy R-SPL Frontmount Intercooler (24R-HG Core) Exhaust Tomei Stainless Turbo Elbow w/ SO2 bung Blitz Stainless 3" Downpipe Catco 3" High Flow Cat (will also include DME Stainless 3'' Test Pipe) Blitz Realize TT-R Full Stainless Cat-Back Exhaust Cooling Koyo Aluminum Radiator New OEM Fan, Fan Clutch and Fan Shroud SAMCO Radiator Hose Set (Black) Brakes Wilwood Forged Superlite Calipers/Pads and 2-piece Rotors (Front) Cross-Drilled Rotors and Hawk Performance Pads (Rear) Stainless Steel Lines Tokico Z32 17/16'' Brake MC Suspension/Wheels Stance Al+Pro Coilovers (9/7 kg/mm front/rear spring rates) SPL PRO v2 Tension Rods (Black) OEM 5-Lug Hubs ARP +15mm/+20mm front/rear Wheel Studs Muteki SR48 Black Open End Lug Nuts Nismo Power Brace GReddy Front Strut Tower Brace Solid aluminum Rear Subframe Mounts/Bushings Steering OEM Rack, Modified for Power Steering Deletion SPL Polyurethane Rack Bushings OEM Z32 Inner Tie Rods SPL V5 Outer Tie Rods Body/Aero Repainted in original Blue Emerald (FN2) by True Performance in Plain City, Ohio, May 2009 (includes limited lifetime warranty) JDM Front and Rear Bumpers/Valences Drift Armor Front Bash Bar (powdercoated semi-gloss black) OEM Kouki Headlights and Taillights VIS Carbon OEM-Style Hood Aerocatch Plus-Flush Hood Latches Interior 2 x Status Ring FRP Cloth Racing Seat on Nagisa/Nams Auto Super Low Seat Rails 2 x Sabelt Steel Pro 6 Point Harness Mazworx S14 Harness Bar (Wrinkle Black) Nardi Classic Deep Corn 350mm Wheel NRG Version 2.5 Quick Release and Short Hub Kognition Design Carbon Radio Delete Panel Electrical Braille B2015 Lightweight AGM Battery (mounted behind passenger seat) Functional Kill Switch Stack Pro Stepper Motor Boost Gauge Please PM me if you are interested and have any questions. Current (as well as some older) photos can be viewed on Google photos album here: https://goo.gl/photos/gLgGBVF3faxBuaFF8 Asking price: $11.5K (Or Best Offer)
Car looks like a great build!
However, can we get a readout of the actual vehicle weight?? Last I checked, a full interior SR S14 weighs about 2700-2800 lbs without driver (wet weight). Last I weighed mine with SR and all accessories, with me in it it weighed in right at 3100 lbs (I am 205). I am having a hard time seeing this weighing 500-700 lbs less without some serious lightweight parts ( I still see the stock glass for instance). That is NC miata territory! Also, can you publish the full parts list for the public to view. May save you some headache in the end. GLWS! |
Thanks for the questions RalliartRsX. I've updated my original post with the full list of parts. I've got the corner weighting sheet at home, I'll scan it and add it to the Google Photos album later tonight or tomorrow. Regarding the weight, I agree that a stock 1995 240sx should weigh in around 2800 lbs without driver. This is a non-sunroof base model car though, so I'd expect it started off a bit lower. All of the interior and sound deadening material has been removed, besides the dash, center console and door panels. All of the HVAC and power steering components have been removed. Even the wire harness has been minimized to save weight. Since corner weighting, I've only added the front bash bar and skidplate, which maybe weigh 50lbs total. I'd imagine that this is one of the lightest S14's out there today.
#17 |
![]() Join Date: Nov 2009
Super nice.... intersted in trades by any chance?
#/f/showthread.php?p...09#post6128809 |
#19 | |
#22 |
FYI...I have a set of OEM Kouki seats that match the door panels. I can swap those in if the buyer would prefer instead of the bucket seats.
| kouki, manual transmission, s14, slicktop, sr20det |
