need help with premature wastegate
as soon as the turbo spools the wastegate is opening and killing the turbo but when I unhook the bov line everything is fine the car is a 91 240sx with an rb25det, gt3076r and turbosmart bov and 38mm wastegate the car still needs to be tuned but i need to fix this problem Anybody help me out
#3 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
what are you sourcing your signal line from for the wastegate? is it to a direct source or tee'd off of something?
Slip Gypsies Blog Quote:
Trader Rating: (31)
it really should be a direct line off of the hot pipe, the turbo itself, or if you have no where else to do it, the intake manifold with no tee's.
#6 | |
![]() Join Date: Feb 2008
I run mine (s13 sr) directly off the intake manifold. I'm not a fan of teeing anything off unless it's absolutely neccesary.
Check out the coolest new thing: toddrickkkkk.blogspot.com |
