Identify this connect/wire lead
Hello all. As i was going through my wiring harness of my newly acquired S14 and i found this(circled in red). Anyone know what this could be? If this a factory wire can someone point me to where it is in the FSM? The picture is of the driver side near kick panel. The bolt below the connector in question is M5 in the FSM EL section. Thanks everyone!
some aftermarket garbage PO added, trace it where it goes? \\i can guarantee it isn't inside the loom so will be pretty damn obvious.
@UpshiftEngineering |
