![]() Join Date: Nov 2007
FS: SR, S13 Parts, 350z Parts, Random Stuff Take a Look!
Selling off a lot of stuff that I have accumulated over the years that I no longer need, will be adding more items as I find time to go through them.
Fastest way to contact is txt (951) 634-8222 I believe the prices are fair so I am pretty firm. CHECK NEWEST POSTS FOR NEW ITEMS Stock S13 Sr Rods. $80 CX Racing intake pipe (Only the pipe no filter) I also have 2 Sr/SOHC Ka mafs like the one pictured. $30 for the pipe $20 per maf. Stock Sr injectors. $85 Adjustable actuator for T28. $75 350z Struts with Megan Lowering Springs. $150 S13 Sr Heat shield. $10 2 12" Sub Box. $40 N60 Maf. $50 350z Pressure plate, flywheel, clutch line, throw out bearing, clutch needs replacing. $150 Chuki vents. $15 S13 Sr Exhaust Manifold. $50 S13 Sr Turbo Elbow. $45 S13 Sr Turbo Pipes. $45 350z Reflectors. $15 a pair S13 Sr Intake Manifold with Coolant Lines. $125 S13 Sr Sidemount Intercooler comes with Mounting Bracket not pictured. $125 S13 Silvia JDM Bumper Support. $80 S13 Sr Straight Pipe. $150 S13 Sr Driveshaft. $125 S13 Coupe Rear Bumper. $50 S13 Rear Bumper Support. $80 Also have some 17x8.5+30 17x9.5+30 5x114.3 Gramlight 57S for sale in the wheels and tires section. Last edited by YoungGun; 01-11-2013 at 03:30 PM.. |
whats up with the shell
are u selling the white shell in the photo for the rims an if u are , is the any issues with it please call or tex me 774-360-2031 im located in long beach
![]() Join Date: Jul 2009
bump for a good seller. bought a few things from my boy!
www.PowerAutosports.com |
Injectors sold.
T25 turbo tack welded to Sr manifold with turbo pipes, outlet, coolant and oil lines, oil drain doesn't come with the 02 sensor. Ran great when pulled no smoke at all. $300 |
