S14 Kouki from Italy
Hi,
I don't write here from a long time... well...I'm Ruben, from Italy ![]() I have a Nissan 200sx S14 kouki with sr20det... to be honest this is my second s14 kouki... I bought the first in 2006 and I crash it against a wall in 2010... the specs of the first were: Tein type hr Brembo rotors Ferodo DS2500 Front and rear wheels spacers 25mm Tecnomagnesio wheels 17x8 whiteline front strut brace whiteline rear and front anti roll bar kit silent block energie suspension full exhaust (no silencer) with megan racing manifold apexi induction kit ARC oil pan Ap racing clutch Fidanza flywheel Torque master fuel pressure regulator Walbro fuel pump Hybrid front mount intercooler Blow off HKS SSQV CPS forged pistons 87mm Eagle conrods Head gasket with copper rings Garrett GT30 Deatschwerks injectors 740cc Apexi power fc Turbo timer HKS type 1 Boost controller Greddy profec B specII Road Italia gauge (boost, oil prex, oil temp, egt, air/fuel Momo Race stearing wheel Short shifter B&M and this is the end of this silvia 20 days after crash, I bought my second and current s14a (with some aftermarket stuff) I mixed the two cars with the components still whole and the result is this: Bilstein dampers and eibech springs front big brake kit with 330mm rotors and ebc yellowstuff pads Ferodo DS2500 rear Racemax wheels 17x7.5 et35 wheels spacers 25mm Front strut brace whiteline front strut brace whiteline rear and front anti roll bar kit silent block energie suspension full exhaust (no silencer) with megan racing manifold Z32 maf Alloy radiator with 2 electronic fan Alloy pully kit ARC oil pan Ap racing clutch Fidanza flywheel Sard fuel pressure regulator Walbro fuel pump Blow off HKS SSQV CPS forged pistons 87mm Eagle conrods Head gasket with copper rings Deatschwerks injectors 740cc Apexi power fc Turbo timer HKS type 1 Boost controller Greddy profec B specII Road Italia gauge (boost, oil prex, oil temp, egt, fuel prex, wide band) Momo Race stearing wheel Short shifter B&M turbo td06sl18g XS front mount intercooler
