Old 02-23-2008, 02:08 AM   #1
JohnD1079
JohnD1079 is on a distinguished road
1jz/2jz exhaust on s14
I couldnt find anything on this so here goes.
If i want to swap my s14 with a 1 or 2 jz, i still use the stock exhaust system. Or for better words, any exhaust that i buy for my s14 will fit, its the downpipe that will be modded or made to fit where the cat would be correct?
Also which ones would you recommend for this engine? I know bigger is better for turbo, but wont anything over 3" be overkill for this. Ohh, i hate loudness. Im looking for as quiet as possible.
JohnD1079 is offline   Reply With Quote
Old 02-23-2008, 04:33 AM   #2
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
exhausts are only for THAT chassis.
any s14 exhaust will work as long as the cat is still in the same place.
which means yes, a modded downpipe is necessary.
3" should be perfect.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 02-23-2008, 11:28 AM   #3
B Love
B Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really nice
Yup just a custom downpipe and thats it. Luckily your getting a 1j if you hate loudness its not as loud as an rb and sounds smoother
B Love is offline   Reply With Quote
Old 02-23-2008, 11:31 AM   #4
1985zcar
1985zcar's Avatar
1985zcar is making a name for him/her self1985zcar is making a name for him/her self
Send a message via AIM to 1985zcar
Really? isn't the exhaust manifold on the opposite side on a 1j? I'd be interested to see exhaust pics from underneath on a 1/2j swapped car.
1985zcar is offline   Reply With Quote
Old 02-23-2008, 11:34 AM   #5
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
since the exhaust on jz's are on the right does the downpipe go under the trans over on top of it. i knowit has to go over to the drivers side. also any s14 catback will work like said just keep the cat in the same place
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 02-23-2008, 01:21 PM   #6
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
If I were you, I would seat the motor first and get the driveline angle correct.
Keep in mind how the cylinders line up and which side the exhaust is on. If you want to use any catback meant for a stock car I suggest you leave the cat on and go find a good welder to make your manifold and downpipe.
g6civcx is offline   Reply With Quote
Old 02-23-2008, 02:04 PM   #7
JohnD1079
Yea, i would do that as well, but my stock exhaust is rusted out, and i need a new one, and im not gonna buy one now, and then get another one made when i swap it eventually.
I know that the exhaust is on the other side, and from what i read Here (H.), all you need is a 45 degree bend, but ive also heard that then the exhaust will be too low and you'll scrape/get ripped off.
Old 02-23-2008, 02:27 PM   #8
B Love
Do exhaust thru the car like that one cefiro lol
Old 02-23-2008, 02:40 PM   #9
GSXRJJordan
GSXRJJordan's Avatar
Yes, the exhaust side is opposite. The chassis doesn't have a whole lot on the other side (just the LSD/axles to worry about IIRC), so you could have it exit the other side. You could also have it cross over below (thanks Deftec) the tranny/bell housing, depending on where you mount the motor.
What you're not realizing is that these swaps are not "plug and play", and therefore some piping/etc needs to be made. Get the motor in, get the intercooler set up, get the driveline set, THEN worry about exhaust. The exhaust should be the last thing you worry about (and then just go with a resonator and a muffler and some blastpipes/etc... make something custom).
Old 02-23-2008, 03:28 PM   #10
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
There are some guys that have had custom exhausts ran down the passenger side and exit in the normal position. The majority of them just have a downpipe cross over to the stock exhaust(it will go UNDER the trans bellhousing of course).
I'm just going to have a shop run me one across to my N1 so I don't have to pay for a whole new setup. As others said though, worry about that last since you don't necessarily NEED that to get the car up and running.
Deftec is offline   Reply With Quote
Old 02-23-2008, 08:19 PM   #11
JohnD1079
I know its the last thing I should worry about becasue i cant just get mandrel bent to whatever position i need after the downpipe, im just not gonna drive around with a rusted exhaust for a year or so.
